rossg Posted September 18, 2008 Report Posted September 18, 2008 how do i remove my front speakers on my 94 cutlass vert? If any one knows please let me in on the secret. My driver side speaker seems bad.Pictures are also helpful. I also want know if there is a way to get more bass from the stock speaker locations. i am using 6.5 pioneers in the rear and i guess they are stock up front. HELP Quote
Crazy K Posted September 18, 2008 Report Posted September 18, 2008 remove cluster bezel -5 screws on top. be careful with the top switch, disconnect it from the harness and LEAVE it attached to the bezel. remove glovebox insert. remove defroster grill and the finned grill beneath it. remove 6 7mm bolts. two, one to the far left of the cluster and to the right of the radio two hidden by the glove box insert two hidden from view under the defrost grid. if you have HUD, you will have to pull two more 7mm bolts directly beneath the HUD unit. Quote
rossg Posted September 19, 2008 Author Report Posted September 19, 2008 remove cluster bezel -5 screws on top. be careful with the top switch, disconnect it from the harness and LEAVE it attached to the bezel. remove glovebox insert. remove defroster grill and the finned grill beneath it. remove 6 7mm bolts. two, one to the far left of the cluster and to the right of the radio two hidden by the glove box insert two hidden from view under the defrost grid. if you have HUD, you will have to pull two more 7mm bolts directly beneath the HUD unit. K you are the master I have had the dash bezel off a couple times no problem there. I see what you are saying with the upper grills. I also have a hud coming is it going to be a bear to install? It is from a 93 or 95 grand prix am I going to have to wire it in or is it plug and play. Do you have an extra dic lying around? Quote
GP1138 Posted September 20, 2008 Report Posted September 20, 2008 Do you have an extra dic lying around? You haven't been here long, or you haven't been paying attention. I'll bet he has 6 laying around. I'm probably off on that number, but I'm sure it's more, not less. Quote
Crazy K Posted September 20, 2008 Report Posted September 20, 2008 more! and I can't find them! I forgot where they are! LOL!!!! uh... while people have installed the HUD units from a 91-93gp into a 88-94 cs, it takes a bit of work and nver quite looks right. Torotoro? and who did the other in a 3800 powered cs???? Quote
