89GP_SE Posted September 15, 2008 Report Share Posted September 15, 2008 Well the fuel pump in my car is dead, I was wondering if it would be possible to install an inline fuel pump somewhere on the fuel rail instead of pulling out the one in the tank? Quote Link to comment Share on other sites More sharing options...
Andrew Posted September 15, 2008 Report Share Posted September 15, 2008 no matter what you will have to pull the tank, so might as well replace the one in there and keep things simple. Quote Link to comment Share on other sites More sharing options...
89GP_SE Posted September 15, 2008 Author Report Share Posted September 15, 2008 no matter what you will have to pull the tank, so might as well replace the one in there and keep things simple. but what if i get those ones that can be mounted on the frame or something, then would I have too. Quote Link to comment Share on other sites More sharing options...
BXX Posted September 15, 2008 Report Share Posted September 15, 2008 no matter what you will have to pull the tank, so might as well replace the one in there and keep things simple. but what if i get those ones that can be mounted on the frame or something, then would I have too. you will have to remove the one from the tank and add a tube in its place. The stock pump in place not running will cause such a huge ass restriction, you wouldnt have enough fuel to run the car and the inline pump would quickly burn up.., Dropping the tank shoudl only take about 20 minutes. All in all, changine the pump is easily done in about an hour Quote Link to comment Share on other sites More sharing options...
89GP_SE Posted September 15, 2008 Author Report Share Posted September 15, 2008 no matter what you will have to pull the tank, so might as well replace the one in there and keep things simple. but what if i get those ones that can be mounted on the frame or something, then would I have too. you will have to remove the one from the tank and add a tube in its place. The stock pump in place not running will cause such a huge ass restriction, you wouldnt have enough fuel to run the car and the inline pump would quickly burn up.., Dropping the tank shoudl only take about 20 minutes. All in all, changine the pump is easily done in about an hour if you dont live in canada Quote Link to comment Share on other sites More sharing options...
BXX Posted September 15, 2008 Report Share Posted September 15, 2008 what does living in Canada have to do with doing a fuel pump job Quote Link to comment Share on other sites More sharing options...
slick Posted September 15, 2008 Report Share Posted September 15, 2008 Rust. Quote Link to comment Share on other sites More sharing options...
5speedz34 Posted September 15, 2008 Report Share Posted September 15, 2008 FWIW:There is a good write up on the TGP forum. Quote Link to comment Share on other sites More sharing options...
meltboy1 Posted September 15, 2008 Report Share Posted September 15, 2008 Rust. cars only rust in Canada?...lol Quote Link to comment Share on other sites More sharing options...
White93z34 Posted September 15, 2008 Report Share Posted September 15, 2008 just did my fuel pump, even being a northern car, took about 2 hours tops. Quote Link to comment Share on other sites More sharing options...
BXX Posted September 15, 2008 Report Share Posted September 15, 2008 Rust. lol. I live in the snow belt in NE Ohio.. I know all about rust Quote Link to comment Share on other sites More sharing options...
slick Posted September 15, 2008 Report Share Posted September 15, 2008 Some rust worse than others. Not simplying implying that Canada cars will rust worse, however, his car may be very rusty. All depends on how well it was taken care of. Quote Link to comment Share on other sites More sharing options...
89GP_SE Posted September 15, 2008 Author Report Share Posted September 15, 2008 Some rust worse than others. Not simplying implying that Canada cars will rust worse, however, his car may be very rusty. All depends on how well it was taken care of. yeah its not that bad underneath, but it is still gonna be a pain, got the pump today and im gonna rip her out today. Quote Link to comment Share on other sites More sharing options...
