94Z34OWNR Posted September 12, 2008 Report Posted September 12, 2008 Im just wanting to know if anybody knows where the wires from them lead to? Do they lead to the headunit,or do they run off the dash speakers?Ive tried all the wires behind the cd player with no luck.Any help would be appreciated,Thanks. Quote
Addicted2bass Posted September 12, 2008 Report Posted September 12, 2008 Does it have the Bose system? Quote
94Z34OWNR Posted September 12, 2008 Author Report Posted September 12, 2008 It did have the bose system but the previous owner removed it. Quote
94Z34OWNR Posted September 12, 2008 Author Report Posted September 12, 2008 Soo, im assuming nobody has an answer for me? Quote
Addicted2bass Posted September 13, 2008 Report Posted September 13, 2008 Is this all factory system? If it has/had a bose system the wires would run to an amp. But if it was removed it should have been rewired and the wires should be behind the radio. Test them with a tone generator or a battery. Quote
94Z34OWNR Posted September 13, 2008 Author Report Posted September 13, 2008 It did have the bose system.The amp and radio had been removed.I put an aftermarket headunit and speakers in it.The dash and rear speakers work,but the ones in the doors dont.They are hooked up but for some reason they won't work.I've checked all the wires behind the radio and none seem to go to the door speakers.The wires in the dash speakers have been changed.I'm thinking they might have been connected to those,but the person that changed them never hooked them back up.I wish i knew exactly how they were setup from the factory. Quote
Andrew Posted September 13, 2008 Report Posted September 13, 2008 just run some new wire yourself. save all the hassle and guesswork. also, i dunno of many aftermarket HU's that are designed to run 6 speakers. so unless you are going to run a crossover, things wont work right. Quote
AL Posted September 13, 2008 Report Posted September 13, 2008 i can check for you within the next week... the 5 speed i bought has the door speakers and ill be removing the dash so i can check out how its run Quote
Crazy K Posted September 13, 2008 Report Posted September 13, 2008 the factory bose system had NO dash speakers. and the front speakers were fed off of the amp IIRC. Quote
94Z34OWNR Posted September 13, 2008 Author Report Posted September 13, 2008 Thats weird because i have a pair of 4x6's in the front,6x9's in the back,and 4 inchers in the door. Quote
Andrew Posted September 13, 2008 Report Posted September 13, 2008 there were still provisions there for the dash speakers since its the same dash as non Bose cars, but with the Bose setup they did not install any speakers there. so whoever had your car before installed those. Quote
94Z34OWNR Posted September 13, 2008 Author Report Posted September 13, 2008 O ok i understand what you're saying.The problem's solved now.I just removed the kicker panels and spliced the wires back there to mine own and ran them to the radio.Everything is working now.Thanks to everybody who responded to my question. Quote
