1tinindian Posted September 9, 2008 Report Share Posted September 9, 2008 I have this mirror I am installing in my GTP and I have searched without finding what I need. It has: 2 pink wires 1 black wire 1 green wire 1 gray wire What are they and where do they go? Are all of them used? Thanks so much for any help. I think the mirror came out of a 93-95 DeVille?!? Leon Quote Link to comment Share on other sites More sharing options...
ManicMechanic Posted September 9, 2008 Report Share Posted September 9, 2008 Pin 1 (should be pink) is switched hot Pin 2 (should be green?) goes to the reverse light switch, doesn't have to be hooked up apparently and pin 3 is ground (black) The others go to the side mirrors on the Cadillac... Quote Link to comment Share on other sites More sharing options...
1tinindian Posted September 9, 2008 Author Report Share Posted September 9, 2008 Pin 1 (should be pink) is switched hot Pin 2 (should be green?) goes to the reverse light switch, doesn't have to be hooked up apparently and pin 3 is ground (black) The others go to the side mirrors on the Cadillac... OK, my pins go like this: 1- pink 2-black 3-green 4- gray 5-pink So if I go by your colors, I only need to run power (switched) to the #1 pink, and my #2 black, to ground, and both the auto dim AND compass will be powered up when the key is on? Sorry to repeat, I'm just wanting to be clear on this before I start running wires. Thanks!! Quote Link to comment Share on other sites More sharing options...
ManicMechanic Posted September 9, 2008 Report Share Posted September 9, 2008 That's correct! Quote Link to comment Share on other sites More sharing options...
1tinindian Posted September 9, 2008 Author Report Share Posted September 9, 2008 That's correct! Thanks! I'll post again after it's wired and done! Leon Quote Link to comment Share on other sites More sharing options...
