oldscsc Posted September 8, 2008 Report Posted September 8, 2008 Thinking about getting one to prolong the life of my transmission. Recommendations on brand or model? I don't need the best of the best, just something that does what it's supposed to do. Thanks Quote
ManicMechanic Posted September 8, 2008 Report Posted September 8, 2008 http://www.oreillyauto.com/EW3/ProductDetail.do?id=372525737&line=HDN&itemNumber=403&categoryIndex=7&didSearchFor=Cooler&vehicle=1990PONTIACGRAND%20PRIXMCLARENV6-191%20%203.1L&bid=1220897409137&cycleCount=1074¤tPage=0 If the link works, that's what I installed. Quote
oldscsc Posted September 8, 2008 Author Report Posted September 8, 2008 It shows everything from $12.99 to $61.99. TGP should work since they're the same transmission, but which one did you buy? I'd probably do middle of the line myself... Quote
xtremerevolution Posted September 8, 2008 Report Posted September 8, 2008 This might help. http://www.w-body.com/forum/index.php?topic=62889.15 $50 is what it cost me, and another $8 or so for the fittings, which you *need*. Quote
Crazy K Posted September 8, 2008 Report Posted September 8, 2008 Don't forget... on a convertible you need to watch out for clearance on the cross brace in front of the radiator/condenser. Also, be careful of the temp sensor, otherwise you might get it in the heat path. Move it if needed. Quote
oldscsc Posted September 8, 2008 Author Report Posted September 8, 2008 Don't forget... on a convertible you need to watch out for clearance on the cross brace in front of the radiator/condenser. Also, be careful of the temp sensor, otherwise you might get it in the heat path. Move it if needed. I knew it couldn't be that easy Quote
55trucker Posted September 8, 2008 Report Posted September 8, 2008 Dana markets a line of coolers under the names..*Long* & *True Cool*.....I should think that a 10,000lb. cooler would do the job nicely. Quote
