5speedz34 Posted September 6, 2008 Report Posted September 6, 2008 My service manual says 184 ft-lbs. Umm, I don't have anything that goes that high, so what should I do? Quote
slick Posted September 6, 2008 Report Posted September 6, 2008 5 foot pool with your socket wrench should do the trick. Quote
Crazy K Posted September 6, 2008 Report Posted September 6, 2008 I have always estimated how much torque I put on it. if you happen to weigh 184 pounds, and stand on a 1 foot long bar, you will properly tighten it. since i use my own breaker bar, at 2 feet out I can put 92 pounds... and I usually put about half my wieght on the bar at that point... so it will be tight. Quote
jeremy Posted September 6, 2008 Report Posted September 6, 2008 if you happen to weigh 184 pounds, and stand on a 1 foot long bar, you will properly tighten it. If Tony used that procedure, he would torque it to about 350lbs seriously though, do you have a pneumatic impact wrench? Quote
5speedz34 Posted September 6, 2008 Author Report Posted September 6, 2008 I can tighten it, but I don't want to under tighten or over tighten it. I don't have an impact and my torque wrench goes to 150 ft-lbs. Quote
Crazy K Posted September 6, 2008 Report Posted September 6, 2008 well... tighten to 150... and then put some more on. I've never actually torqued those nuts. p.s. grease up the splines so nothing will be bound up if you have to remove it again. Quote
Brian P Posted September 7, 2008 Report Posted September 7, 2008 if you happen to weigh 184 pounds, and stand on a 1 foot long bar, you will properly tighten it. If Tony used that procedure, he would torque it to about 350lbs seriously though, do you have a pneumatic impact wrench? LMAO!!! Just make it as tight as possible. Do the 150 to get a feel for it, then go another 10 degrees or so. Quote
GP1138 Posted September 7, 2008 Report Posted September 7, 2008 You don't want to impact tighten the axle nut, because you could fuck up the wheel bearing. Torquing it with a wrench and a cheater should be just fine. Quote
jeremy Posted September 7, 2008 Report Posted September 7, 2008 You don't want to impact tighten the axle nut, because you could fuck up the wheel bearing. Torquing it with a wrench and a cheater should be just fine. out of curiousity's sake, how would tightening it to the proper torque using an impact cause damage? Quote
GOT2B GM Posted September 7, 2008 Report Posted September 7, 2008 I just put my electric impact on it and rattle it tight. Never had a problem. Quote
Brian P Posted September 7, 2008 Report Posted September 7, 2008 I've gotta x2 that. I've rattled things tight that I shouldn't have a million times (I'm lazy) and here I am. Quote
GP1138 Posted September 7, 2008 Report Posted September 7, 2008 You don't want to impact tighten the axle nut, because you could fuck up the wheel bearing. Torquing it with a wrench and a cheater should be just fine. out of curiousity's sake, how would tightening it to the proper torque using an impact cause damage? I was just always told not to use an impact when I worked at the shop. Quote
