sws2000 Posted September 5, 2008 Report Share Posted September 5, 2008 How hard or easy is it to replace an AC clutch on a 95 Monte 3.1? Do I need any specialty tools? My AC stop blowing cold air the other day and my first suspicion is the clutch since it's not engaging and for the last month or two it has been whining when the AC wasn't turn on...turn the AC on and the whining stops (it's not doing this anymore.) I know there's a chance it could be low on 134a and this weekend I'll bypass the relay to check but something tells me it's the clutch. Quote Link to comment Share on other sites More sharing options...
J Posted September 5, 2008 Report Share Posted September 5, 2008 on my 94 3100 i dropped the subframe a little, i don't recall using any speciality tools. The clutch will stop turning on due to it being almost empty of 134a, i had to trick mine to turn on with the relay so it would suck 134a into the system. It's been a few years since i've done it, i'm sure someone with more info will chime in soon. Best of luck, jay Quote Link to comment Share on other sites More sharing options...
Crazy K Posted September 5, 2008 Report Share Posted September 5, 2008 probably not the clutch. probably low on charge. then again... those 94-95 compressors all go bad. Quote Link to comment Share on other sites More sharing options...
rockfangd Posted September 5, 2008 Report Share Posted September 5, 2008 they go bad way past 95 lol i see them bad all the time all the way up to 2003 Quote Link to comment Share on other sites More sharing options...
DavidHowell3633 Posted September 9, 2008 Report Share Posted September 9, 2008 Before I knew better, I ordered a new clutch for my 94. The bearing was shot and still blowing cold. I bought a removal tool off of ebay from some tool company and broke it easily. Then, they first refused to replace it since they didn't understand what I told them. They later sent a replacement part that was almost as soft as clay and it bent. Probably from Taiwan. Long story short, I have a new clutch still in the box never used. Rather than hassle around with removing and installing the clutch- I've done it before without problems- I bought a reman compressor and said to h*** with it. If you want my clutch, I'll sell it cheap. Make me an offer if you're a masochist. Thanks. Quote Link to comment Share on other sites More sharing options...
sws2000 Posted September 11, 2008 Author Report Share Posted September 11, 2008 Let me bypass the relay first to make sure it is the clutch and I'll get back with you. Quote Link to comment Share on other sites More sharing options...
