1990lumina Posted September 1, 2008 Report Posted September 1, 2008 Title says it all basically. The Lumina is running like ass still, and it needs to get fixed so I can sell it. At idle isn't always trying to find somewhere to idle at but is bouncing between 300rpm and 1200rpm all the time. I've tried unplugging the TPS, MAP (there are two sensors back at the firewall, one is the MAP not sure what the other one is), IAC, EGR and O2 sensor thinking that the ECM might resort to open loop for that sensor and make the car run better but it doesn't seem to matter much. The car only has 180,000km on it so I don't think the injectors could be THAT fucked up, but I'd like to test them anyways. Any way to do it without pulling the upper plenum off? This spring with the Tech1 it was showing the long term block learn to be very low..like 100 or so. Apparently that means it's trying to pull fuel, but obviously the ECM is unsuccessful at doing it because it still idles like shit. The second you mash the gas it'll light the tires up and go still (as goodf as it ever did). Plugs, wires, coils are all okay. Fuel filter has been replaced. Good fuel pressure. The PCV valve is new. The fuel pressure regulator checks out (no tears in the diaphram). I don't know WTF is wrong with this car. Other than a vacuum leak which I can't find I don't know where else to check. Quote
mfewtrail Posted September 1, 2008 Report Posted September 1, 2008 Jeff, you can ohm them out without removing the plenum. Check out this old post here(specifically the 1st post on page 2, the link I'm posting should take you directly there). http://www.w-body.com/forum/index.php?topic=17359.msg177493#msg177493 Quote
BXX Posted September 1, 2008 Report Posted September 1, 2008 ^^^That is not a proper way to test them at all... Pull the plenum (takes like 10 minutes if that) and test them correctly. Otherwise, you end up testing 3 of them and the wiring and connections for resistance.. And I have seen the early Multec injectors read very high and very low.. Should be self explanitory from there Quote
carkhz316 Posted September 1, 2008 Report Posted September 1, 2008 Don't forget that Ohm'ing them out can only really condemn one electrically if it's outta spec. Even if it's within spec, it could still be flowing incorrectly, so a balance test is the best way to test for this. Quote
carkhz316 Posted September 1, 2008 Report Posted September 1, 2008 (I didn't read all of the post originally), if you can get your hands on a vacuum gauge, hook it up to the manifold end of any and all vacuum lines, pump 'er up, and listen for leaks (engine off of course) Quote
1990lumina Posted September 1, 2008 Author Report Posted September 1, 2008 Does Autozone or places like that normally rent out a tool to pulse the injectors individually to do a balance test? Since my car is OBD1 I don't think it's possible to do through the scan tool. And I don't want to spend over $100 on a tool I'll use once. Quote
Night Fury Posted September 1, 2008 Report Posted September 1, 2008 Once?! You will use it once a week! And all of the 3.1 owners on here would beg you to borrow it constantly!! Quote
Pontiac6KSTEAWD Posted September 1, 2008 Report Posted September 1, 2008 The only way to acurately test the injectors is to pull the upper intake plenum. You can test the bank on the end harness. However, that tests all 3 at the same time. Since 12 ohm is the line for good, and one tests out at 10 ohm, and the other two test at 13 ohm. Its going to read 36 ohm, which would indicated a good ohmage, but there is a bad injector. When one injector goes, it can make the whole bank of 3 run like ass or not run at all.. Quote
1990lumina Posted September 7, 2008 Author Report Posted September 7, 2008 I pulled the plenum and tested all 6 injectors, results as follows: Cylinder: 1 - 13.2 ohms 2 - 8.2 ohms 3 - 13.2 ohms 4 - 9.8 ohms 5 - 7.6 ohms 6 - 12.5 ohms From the above readings would you guys say this is why my car idles like complete ass (revs itself, hunting, etc..) I also believe upper plenum rear gasket was leaking since I had sprayed a bunch of Seafoam around that area and the gasket had on top and underneath all the way to the runners for cylinder 2 and 4. Also, what's the trick to pulling the fuel rails? I want to see if any of the injectors are leaking, but they won't seem to let go of their hole lol. I have the 4 bolts out and the rails move around - just the injectors won't break free. Quote
Crazy K Posted September 7, 2008 Report Posted September 7, 2008 You have BAD injectors. they may be responsible for your issues. need some injectors? Quote
ns87 Posted September 7, 2008 Report Posted September 7, 2008 I just gave mine a good solid tug. They're just held in with that rubber O-ring Quote
1990lumina Posted September 7, 2008 Author Report Posted September 7, 2008 You have BAD injectors. they may be responsible for your issues. need some injectors? If you have 6 that are close to 12ohms I'd do anything to get some. How much do you want Ken? Quote
Night Fury Posted September 7, 2008 Report Posted September 7, 2008 3.1+oldness+fuel injectors=FAIL. Quote
Crazy K Posted September 7, 2008 Report Posted September 7, 2008 You have BAD injectors. they may be responsible for your issues. need some injectors? If you have 6 that are close to 12ohms I'd do anything to get some. How much do you want Ken? PM sending.... Quote
kwk39018 Posted September 7, 2008 Report Posted September 7, 2008 I pulled the plenum and tested all 6 injectors, results as follows: Cylinder: 1 - 13.2 ohms 2 - 8.2 ohms 3 - 13.2 ohms 4 - 9.8 ohms 5 - 7.6 ohms 6 - 12.5 ohms From the above readings would you guys say this is why my car idles like complete ass (revs itself, hunting, etc..) I also believe upper plenum rear gasket was leaking since I had sprayed a bunch of Seafoam around that area and the gasket had on top and underneath all the way to the runners for cylinder 2 and 4. Also, what's the trick to pulling the fuel rails? I want to see if any of the injectors are leaking, but they won't seem to let go of their hole lol. I have the 4 bolts out and the rails move around - just the injectors won't break free. Time for ford injectors Quote
Pontiac6KSTEAWD Posted September 8, 2008 Report Posted September 8, 2008 Well, really, you only need 3 injectors. But replacing them as a set is usually best. Quote
1990lumina Posted September 8, 2008 Author Report Posted September 8, 2008 So the 13.2ohm ones are still decent or?? I don't want to sound like a cheap ass, but this car is worth fuck all so cheaper the better. I'll probably do all 6 though. Quote
Pontiac6KSTEAWD Posted September 8, 2008 Report Posted September 8, 2008 3 of them are good. All the ones above 12 ohms.. Quote
1990lumina Posted September 8, 2008 Author Report Posted September 8, 2008 What is the stock flow rate and such for my shitty injectors? Quote
mfewtrail Posted September 8, 2008 Report Posted September 8, 2008 What is the stock flow rate and such for my shitty injectors? 3.1 MPFI injectors are supposed to be 16.7 lbs/hr. Quote
1990lumina Posted September 11, 2008 Author Report Posted September 11, 2008 Threw in some cheap reman injectors and it's running fantastic again. I haven't seen it run this well for over a year. I'm super happy. Quote
1990lumina Posted September 11, 2008 Author Report Posted September 11, 2008 Thanks again for the offers Ken - if I didn't need the car back together during this week I wouldn't have bought the reman injectors. But time was the only reason I didn't buy from you!! Quote
Crazy K Posted September 11, 2008 Report Posted September 11, 2008 fine by me. back to work.... "fuel injectors, used Ohm checked fuel injectors!" Quote
