swift13 Posted August 31, 2008 Report Posted August 31, 2008 Yeah see i got this problem with my 95 csc where the window switch only works on the drivers side(the master switch) for all 4 windows but the other switches dont work at all. also the mirror switch only works half assed sometimes im assuming a short but who knows... Anybody have or had this problem and know a good solution?? Quote
rockfangd Posted August 31, 2008 Report Posted August 31, 2008 ok the master switch has a lock button for the windows if it is pushed the 3 other windows will not work. If it is not pushed it is a bad master switch. As for the mirror switch it is probably faulty Quote
swift13 Posted September 1, 2008 Author Report Posted September 1, 2008 well as im not a complete idiot its not the master switch lock or the switch itself i should have mentioned that already so my bad what im wondering is what is my next step in figuring out this problem?? Quote
cutlassdude96 Posted September 1, 2008 Report Posted September 1, 2008 I think master switch is bad Quote
Crazy K Posted September 1, 2008 Report Posted September 1, 2008 I think master switch is bad x2 it controls the other switches. I believe you could sub a 95-97 sedan switch if necessary. Quote
rockfangd Posted September 1, 2008 Report Posted September 1, 2008 well i always have to bring that up because sometimes you just never know Quote
swift13 Posted September 1, 2008 Author Report Posted September 1, 2008 well i always have to bring that up because sometimes you just never know yeah i understand as i said i should have mentioned that. but i honestly dont think the master switch is bad i have a few other switches that ive tried cuz i thought the same thing. and the car still has the same problem. Is there any type of module or something the this switch goes to?? that could cause this problem. thank you for your replys and thanks in advance for the others. Quote
ManicMechanic Posted September 1, 2008 Report Posted September 1, 2008 Not sure about 1995s, but 1990-94s have an All Windows Down Module in the dash where the factory amp normally goes. Quote
swift13 Posted September 1, 2008 Author Report Posted September 1, 2008 i know the 95s have the all windows down switch but i now bout the module i should check, where is that located exactly.?? i dont see why they wouldnt have it if the others do but i wouldnt be surprised Quote
ManicMechanic Posted September 1, 2008 Report Posted September 1, 2008 Crazy K would know for sure. I have never stripped a 1995 convertible. Quote
