CutLoose Posted August 31, 2008 Report Posted August 31, 2008 Hi guys, need help. Anyone had problems and/or know a fix for the front window switches not lighing up? Only the driver's unlock switch lights up, the rest are out. I haven't pulled any switches out since Ill be putting door check links in after they're painted, so I'd work on it then while the panels are off. Quote
swift13 Posted September 1, 2008 Report Posted September 1, 2008 i would think maybe a short in the wiring or just the switchs need be replaced i think mine are the same, way no lights. NO couldnt be a common problem with a gm car!! Quote
Addicted to eaton Posted September 2, 2008 Report Posted September 2, 2008 Just change them out. Bulbs Blow ! Quote
CutLoose Posted September 2, 2008 Author Report Posted September 2, 2008 Anthony said: Just change them out. Bulbs Blow ! Not the case, I just checked one of the inop bulbs with a battery, lights up fine. Maybe a broken door jamb wire? I'll have to explore this further. Quote
Brian P Posted September 2, 2008 Report Posted September 2, 2008 check the contacts on the circuit board that the bulbs sits in. Quote
CutLoose Posted September 5, 2008 Author Report Posted September 5, 2008 I found it....the pass switch had the terminal folded over in the switch, and the driver's is one of the 2 bulbs out. found a Tahoe switch at work to rob a bulb from and solder it in. Thanks. Quote
