xtremerevolution Posted August 30, 2008 Report Share Posted August 30, 2008 I believe they're 3157 bulbs, and I need them because I just covered my tail light with niteshade and I'd like some more lighting power. The problem is that they need to be able to light up as either parking lights or brake lights. I've looked at these so far, but I'm unsure of whether or not they'll work well: http://www.eautoworks.com/search-ALL/mk38-md371-mc1995-bu18.htm Any opinions or suggestions would be appreciated. I need to buy two pairs ASAP. Quote Link to comment Share on other sites More sharing options...
kwk39018 Posted August 30, 2008 Report Share Posted August 30, 2008 Ya,you should go with a LED,but that is way to much.Check Advanced Auto.You will also need restors so your bilnkers are not crazy fast. Quote Link to comment Share on other sites More sharing options...
xtremerevolution Posted August 30, 2008 Author Report Share Posted August 30, 2008 Ya,you should go with a LED,but that is way to much.Check Advanced Auto.You will also need restors so your bilnkers are not crazy fast. I tried the ones at advance auto and not only are they a lot more expensive, but they simply don't work because their output is like 25 degrees, vs. the 180 advertised on some of these here. They light up a circle on the tail light lens and that's it. Quote Link to comment Share on other sites More sharing options...
xtremerevolution Posted August 31, 2008 Author Report Share Posted August 31, 2008 You think this might do the trick? http://cgi.ebay.com/ebaymotors/3157-Super-White-63-LED-Light-Bulb-Signal-Back-up-3057_W0QQcmdZViewItemQQcategoryZ33713QQihZ025QQitemZ380058233532QQrdZ1QQsspagenameZWDVW Quote Link to comment Share on other sites More sharing options...
Brian P Posted August 31, 2008 Report Share Posted August 31, 2008 do 3357's (or 3457's), they're slightly brighter by a few watts! Quote Link to comment Share on other sites More sharing options...
kwk39018 Posted August 31, 2008 Report Share Posted August 31, 2008 You think this might do the trick? http://cgi.ebay.com/ebaymotors/3157-Super-White-63-LED-Light-Bulb-Signal-Back-up-3057_W0QQcmdZViewItemQQcategoryZ33713QQihZ025QQitemZ380058233532QQrdZ1QQsspagenameZWDVW Yea this look a little better,and cheaper. Quote Link to comment Share on other sites More sharing options...
Crazy K Posted August 31, 2008 Report Share Posted August 31, 2008 You think this might do the trick? http://cgi.ebay.com/ebaymotors/3157-Super-White-63-LED-Light-Bulb-Signal-Back-up-3057_W0QQcmdZViewItemQQcategoryZ33713QQihZ025QQitemZ380058233532QQrdZ1QQsspagenameZWDVW Yea this look a little better,and cheaper. SEE IF YOU CAN GET RED. white LEDs allegedly make your tail lights appear pink. plus make sure is is a dual circuit bulb, so it has park and brake both. Quote Link to comment Share on other sites More sharing options...
xtremerevolution Posted August 31, 2008 Author Report Share Posted August 31, 2008 do 3357's (or 3457's), they're slightly brighter by a few watts! Not a bad idea. I'll go pick up some of those till my LED lights come in. I already ordered two bulbs btw. If these work well I'll go ahead and order a second pair. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=025&sspagename=STRK%3AMEWN%3AIT&viewitem=&item=380059680100&rd=1 Quote Link to comment Share on other sites More sharing options...
Venom Posted August 31, 2008 Report Share Posted August 31, 2008 You think this might do the trick? http://cgi.ebay.com/ebaymotors/3157-Super-White-63-LED-Light-Bulb-Signal-Back-up-3057_W0QQcmdZViewItemQQcategoryZ33713QQihZ025QQitemZ380058233532QQrdZ1QQsspagenameZWDVW Wow I just picked up a pack of 100 LEDs for that much. Let us know how they work for ya. Quote Link to comment Share on other sites More sharing options...
