ManicMechanic Posted September 26, 2008 Report Posted September 26, 2008 I'm in Austin. I don't have an alt for your car though...Usually I have some spares but not right now. Quote
dreadbel Posted September 26, 2008 Author Report Posted September 26, 2008 Sweet, another w-boy in the area, I was advice to get an acdelco(GMC), they are harder to find. dont know why Can you keep a look out for door parts and left rear light Thank you Quote
ManicMechanic Posted September 26, 2008 Report Posted September 26, 2008 dreadbel said: Sweet, another w-boy in the area, I was advice to get an acdelco(GMC), they are harder to find. dont know why Can you keep a look out for door parts and left rear light Thank you Harold's up in Lampasas has a 1990 International 2 door with everything but HUD. Austin Express on COngress has a couple of newer CS coupes. East End in Del Valle has quite a few CSs as well. I can go with you if you want to hit up either. The owner of East End and myself are good friends. Try some of the AC delco stores in town, there is one on Burnet I think and one in Cedar Park. Quote
dreadbel Posted September 26, 2008 Author Report Posted September 26, 2008 ManicMechanic said: dreadbel said: Sweet, another w-boy in the area, I was advice to get an acdelco(GMC), they are harder to find. dont know why Can you keep a look out for door parts and left rear light Thank you Harold's up in Lampasas has a 1990 International 2 door with everything but HUD. Austin Express on COngress has a couple of newer CS coupes. East End in Del Valle has quite a few CSs as well. I can go with you if you want to hit up either. The owner of East End and myself are good friends. Try some of the AC delco stores in town, there is one on Burnet I think and one in Cedar Park. When i get this bucket running, I will go. any one ever try the Ultima Alternators, they are cheap, i read some where they where own by AC delco Quote
ManicMechanic Posted September 26, 2008 Report Posted September 26, 2008 Unfortunately, you get what you pay for on most remans. Quote
dreadbel Posted September 26, 2008 Author Report Posted September 26, 2008 I think they figured that out. it is $106(stop it from looking cheap) with a core of $45 and a lifetime warranty. Quote
dreadbel Posted October 18, 2008 Author Report Posted October 18, 2008 hey guys and girls. it has been a while I still cannot get the cutlass to run. it will crank but won't start. i had to start for a few tries but then the rpm's will slowly go down then it will die. after a few more it would not start. It has a newly installed gas pump. you can here it when you turn the ignition. i am thinking fuel filter my be the problem, i have not dealt with the fuel filter(i don't won't to blow something up) i am at the verge of selling it, sell for enough for the new parts and paint job.... if only i knew what was wrong. i am going to give another wack at it. so if any one in the area want my baby and has more patience... i got it here from Dallas to georgetown, about a 3 hour drive. yeah so close Quote
AL Posted October 18, 2008 Report Posted October 18, 2008 I hope you find the problem... the same thing is going on with my car... If you hold onto it till I figure out the problem, I will let you know so your not throwing a bunch of parts at it. Quote
RareGMFan Posted October 18, 2008 Report Posted October 18, 2008 Welcome to the site! You're giving up on this too easily. From the sounds of it, you haven't investigated/looked into the problem too much. First of all, you need to determine if it's an electrical problem, or a fueling problem. Have you tested to see if it's getting spark? If you're getting spark, move on to fuel. If not, start looking into the coils and ignition control module. Most parts stores will check these for free for you, and it is very common for these to go out as any GM motor ages. If those are OK, I'd suspect the crank position sensor next. For that, I'd just replace it. They're pretty cheap (maybe $15?), and even if it's not bad now, you're probably going to need one soon enough anyway if it hasn't been replaced. Spray some starter fluid into the intake, and see if it starts. If it starts with that, you know it's a fueling problem (new injectors and pump is not a guarantee that those aren't the problem by any means, especially if they're aftermarket, and not genuine GM parts). Check the fuel pressure. If there is a problem with the pressure, pull the vacuum hose off the fuel pressure regulator, and see if any fuel is leaking out. If there is, the diaphragm inside the fuel pressure regulator is punctured, and you need a new one (very common). If the FPR is fine, then chances are the pump is bad, or weak. If the fuel pressure is fine, check the resistance on all the injectors. If the spark AND fuel check out fine, then I'd look at the computer. You can snag one cheap from a junkyard, swap them out, and see what happens. Quote
ManicMechanic Posted October 18, 2008 Report Posted October 18, 2008 dreadbel said: hey guys and girls. it has been a while I still cannot get the cutlass to run. it will crank but won't start. i had to start for a few tries but then the rpm's will slowly go down then it will die. after a few more it would not start. It has a newly installed gas pump. you can here it when you turn the ignition. i am thinking fuel filter my be the problem, i have not dealt with the fuel filter(i don't won't to blow something up) i am at the verge of selling it, sell for enough for the new parts and paint job.... if only i knew what was wrong. i am going to give another wack at it. so if any one in the area want my baby and has more patience... i got it here from Dallas to georgetown, about a 3 hour drive. yeah so close You want me to come over and help you tackle it? Quote
dreadbel Posted October 23, 2008 Author Report Posted October 23, 2008 it is running, Manicmechanic and I tackle it. no question please, Quote
GP1138 Posted October 23, 2008 Report Posted October 23, 2008 dreadbel said: it is running, Manicmechanic and I tackle it. no question please, You're going to have to elaborate some there. Quote
dreadbel Posted October 23, 2008 Author Report Posted October 23, 2008 Lets say it was a bad sensor in the tank Quote
dreadbel Posted October 23, 2008 Author Report Posted October 23, 2008 TehFailCutty said: Glad you got her runnin! Thanks, when Manicmechanic get some spare time going to replace the sensor for the tank Quote
GPX Posted October 23, 2008 Report Posted October 23, 2008 dreadbel said: it is running, Manicmechanic and I tackle it. no question please, Out of gas, eh? Quote
dreadbel Posted October 23, 2008 Author Report Posted October 23, 2008 redcar_96 said: dreadbel said: it is running, Manicmechanic and I tackle it. no question please, Out of gas, eh? seem to be that..... Quote
jreed10 Posted October 24, 2008 Report Posted October 24, 2008 Sometimes the simplest problems are the ones we don't think about. I'm glad you got her runnin though. It's a great lookin Cutty! Quote
MonteCarloChick Posted November 10, 2008 Report Posted November 10, 2008 I missed this.. but welcome Quote
dreadbel Posted December 4, 2008 Author Report Posted December 4, 2008 Hey guys, been a while since i was on. The Cutlass is still running, barely. Transmission and one of the spark plugs pop out. Happy late Thanks Giving Quote
kwk39018 Posted December 4, 2008 Report Posted December 4, 2008 dreadbel said: Hey guys, been a while since i was on. The Cutlass is still running, barely. Transmission and one of the spark plugs pop out. Happy late Thanks Giving Wow the tranny popped out. Quote
IRONDOG442 Posted December 4, 2008 Report Posted December 4, 2008 dreadbel said: Hey guys, been a while since i was on. The Cutlass is still running, barely. Transmission and one of the spark plugs pop out. Happy late Thanks Giving Two things this guy is either: 1. French Canadian 2. Retarded Only you can be the judge !! Quote
dreadbel Posted December 4, 2008 Author Report Posted December 4, 2008 kwk39018 said: dreadbel said: Hey guys, been a while since i was on. The Cutlass is still running, barely. Transmission and one of the spark plugs pop out. Happy late Thanks Giving Wow the tranny popped out. no no tranny is having some problems with third gear, one of the Sparks in the back came out while i was driving sorry for the miss understanding Quote
