My Engine is Moving
ok i dont know what happend the engine on my Euro 3.4L DOHC automatic what could be the problem it makes a scraping sound when i move any help would be cool
Scraping sound?
In the engine bay? Bottoming out on the frame?
Need more details, please!
- Erik
thats all i know and i just spent $500 for new motor mounts and its the same problem
Is the scraping sound dissapears once you are driving straight on the road/street?
Okay... that's not good.
But, could you e-l-a-b-o-r-a-t-e on your condition?
We may be able to help you out!
- Erik
similar, kinda, not really, almost related issue: my engine sits in the bay (DUH, where else would it sit?) anyways... when you look at the dog bone torque struts, they both seem to angle out from the front of the engine bay and to the left, as if the passenger side of the engine was sitting low... sign of a worn out mount? I tried to take a look for it from underneath, but hell, I can't even SEE the motor mount. any ideas / suggestions? I guess a 2x4 under the oil pan and a jack should raise the engine enough.
2x4 across oil an trans on floor jack will raise it up enough to tell if it the mounts-but u said u've already replaced them--check cv joints or brakes :?:
  • 5 weeks later...
sorry i didnt know what i was talking about ok well i took it back to the mechanic and they told me that the catalytic converter was messed up and the element it side it was causing that scraping sound and the frame wasnt scraping it was just worn spring also my exhaust sound "meaner" its the OEM exhaust too
