gmrulz4u Posted August 10, 2003 Report Posted August 10, 2003 I am trying to remove my damn UB3 cluster dash in my 89 Supreme and I can't get the fuckin' plastic harness to UN-PLUG from the dash!!!!! I can barely even see what the hell I am doing because it doesn't let you pull the dash anywhere NEAR far enough out!! All I can see is the big light-grey plug, and then blue plastic peices that are also connected to the back of the grey plug...I've already removed one blue peice that I believe just keeps the wiring more organized... The thing that is most confusing is the blue part that is still remaining...it has like a blue tab on the bottom of it, but I don't understand what the tab is for...?? I've tried EVERYTHING(so it seems) and have already cut-up my hands in 3 places... ANYONE!!??? THANKS:) Quote
Slade901 Posted August 10, 2003 Report Posted August 10, 2003 Squeeze the tab and use a flat head screw driver to pry out the the connector. Quote
gmrulz4u Posted August 10, 2003 Author Report Posted August 10, 2003 OK, so I squeeze the tab IN-WARD(toward the connector), right, not OUT-WARD...just to make sure... THANKS MAN! Quote
Slade901 Posted August 10, 2003 Report Posted August 10, 2003 OK, so I squeeze the tab IN-WARD(toward the connector), right, not OUT-WARD...just to make sure... THANKS MAN! yep.. in-ward (towards the connector). Try prying on both sides a little bit at a time. Keep pressing the tab while you are trying to pry out the connector. Quote
gmrulz4u Posted August 10, 2003 Author Report Posted August 10, 2003 So I take it from the way you describe it, this is NOT an easy connector to un-plug, eh? Sounds like it don't like being disconnected... Quote
Slade901 Posted August 10, 2003 Report Posted August 10, 2003 It is pretty tight.. once you are able to pry a little bit then that tab is not going to lock anymore and then it would be easy to pull it straight out. Quote
