4T60E VSS?
ManicMechanic
1995 4T60-E. Delayed shift in to second and third and speedo jumpy. The speedo will jump to 50 MPH wil I'm doing a steady 25 MPH. It will go to 4000 RPMs and stay there then finally shit. Not sure if I have 3rd or 4th gear.
VSS?
No 3rd or 4th gear. Speedo goes down to zero and will go back up but real jumpy and then do it all over again.
sounds like it jay!
I might have a spare kicking around, pm me if you want it.
Chris - you are a great man. :D
But she needed it done yesterday. THat's what it was, so far. She drove it all day and said the speedo was steady and it shifted fine.
Glad that fixed it! I had the same Issue a few years back with the lumina.
how difficult was it and how much did it cost, I gota do it to the TGP next weekend.
Part was $44.90 at autozone...It was too hateful, just one bolt. I'm sure it will be a bit more difficult on a TGP. Perhaps removing the alternator will help a lot.
oh? I thought it was more on the drivers side of the car... I have to see where it is located first, the pictures in the haynes book don't help too much...
it's on the pass side on the tailshaft as far as I know, like the 4T60-E, I'm sure someone that knows for sure can chime in here.
She called me up and said it is doing it again....DAMMIT!
check the wiring, I had a issue in my car after I wrecked it, the wiring got damaged then in short time corrosion got to it and really ruined my day
I drove it...The speedo will work for about 20 seconds and then it just dies...It's worse than before.
She says that in the mornings, it's slow to go in to gear...Like a 3-4 second delay and it will slowly start to go...
I will do that.
Ran down to the one open yard and got a computer (after they said they didn't have one, I said let me look and I found 6) and so far, we have all 4 gears, steady speedo (no, not that kind Buck & Travis, LOL!).
