LuckoftheGTP Posted August 20, 2008 Report Posted August 20, 2008 Hey, Im putting in new gauges in my 94 GTP (Volt,Temp,oil PSI) I want to put them in that cubby hole above the vents. (in the newer GTP's where the boost gauge is) First question: Where would the best place to run the Oil Press. and Temp lines? Please keep in mind, not a big fan of major drilling and ripping the entire dash out. (daily driver) Second: What is the Temp. range of the Trans? Thanks Quote
alphagtp Posted August 21, 2008 Report Posted August 21, 2008 Tranny and Oil temps gauges are on my list as well, I'm installing them on the a-pillar tough, I hope we get the help because I have no idea Quote
Venom Posted August 21, 2008 Report Posted August 21, 2008 Its going to be tough to install three gauges up there with the shape of the hole. THe last time I checked I could only install two comfortably. All my wires run behind the dash, behind the radio and then through the firewall for the temp gauge thats in there now. Quote
LuckoftheGTP Posted August 22, 2008 Author Report Posted August 22, 2008 Im using the mini-gauges(1 1/4 or 1 1/2) and they fit. Where is that whole in the fire wall? Quote
