Lonewolf Posted August 18, 2008 Report Posted August 18, 2008 Now I've got the first problem with my Cutty. I hope you can understand and help me.... I changed the rear shock last week because the old one were dead. I bought gabriel gas shocks and put them in. The car drives great and straight, but it makes a bad noise from behind when it rolls slow. I didn't change the strut mount only the shocks. What must I do now and were can I get anything what I need else ?? Thanks for help Ralf from Berlin Quote
slick Posted August 18, 2008 Report Posted August 18, 2008 Is it a clunking or banging type of sound? Generally when you replace the rear shocks you want to replace the mounts as well. Quote
IRONDOG442 Posted August 18, 2008 Report Posted August 18, 2008 You need strut mounts, yesterday !! Quote
Lonewolf Posted August 18, 2008 Author Report Posted August 18, 2008 Have you got an Adress for me were I can buy the right strut ? Quote
Breakdown Posted August 18, 2008 Report Posted August 18, 2008 You might have also lost the bushings. They are like plastic blocks on each side below the uni-leaf. I'll see if I can take a pic of mine, you should be able to just see these looking under the car (if they are there or not). I agree with the comments on the mounts, even if they weren't gone, I would get rid of them, because they'll go. Never been to Germany, what is a Cutlass Supreme doing there, I was under the impression that these cars would not be over there. Quote
Brian P Posted August 18, 2008 Report Posted August 18, 2008 I have to agree if the sound you're hearing is like a "groan" rubbing sound when the suspension travels, it's likely the SPRING bushings at the ends which sit on the strut knuckle. Once the bushings wear thru, the fiberglass spring material rubs against the cast iron strut knuckle and makes a lot of noise. Quote
Lonewolf Posted August 18, 2008 Author Report Posted August 18, 2008 @Breakdown: A picture would help i think. The noise is more a rubbing but only when I roll slow . Can you send me a link were I can buy these things The Shop here in Germany can only deliver the shocks, nothing else. That's the problem when you're alone with a car in the hole country..... But i love my Cutty and i will do all for a long great life for it !!!!!!! Greets Ralf Quote
GOT2B GM Posted August 18, 2008 Report Posted August 18, 2008 NAPA sells them, I'm sure a member could pick up a set and ship them to you. Here you can see the new white isolator pad between the leaf spring and the knuckle. Quote
Breakdown Posted August 18, 2008 Report Posted August 18, 2008 @Breakdown: A picture would help i think. The noise is more a rubbing but only when I roll slow . Can you send me a link were I can buy these things The Shop here in Germany can only deliver the shocks, nothing else. That's the problem when you're alone with a car in the hole country..... But i love my Cutty and i will do all for a long great life for it !!!!!!! Greets Ralf The pic above is pretty much the same thing that I would send (thanks Matt), what you should notice is that your car's back end should be lower than in your picture right now, if it were the bushings, just a little lower. Quote
Breakdown Posted August 19, 2008 Report Posted August 19, 2008 I almost forgot, if it is the bushings (I think that it is) and you don't replace them soon. You will do damage to your brand new struts, they will end up seized (soon = one month or two) Quote
Brian P Posted August 19, 2008 Report Posted August 19, 2008 How are the struts going to be affected by the spring bushings? Quote
Breakdown Posted August 19, 2008 Report Posted August 19, 2008 Bushings keep the struts where they should be, no bushings or completely warn down bushings keep the struts too compact, the wear eventually seizes the struts, or at minimum prevents them from keeping the back end of the car at the height that it should be. Unfortunately I know this from experience. Fortunately the struts had warranty on them at the time so parts were free. I basically ate a new set of struts in 6 months. Quote
Brian P Posted August 19, 2008 Report Posted August 19, 2008 if the rear spring bushings go bad, the only thing that will change is ride height by the amount of the bushing thickness (~3/8"). I've seen struts go bad quicker from improper installation (such as spinning the strut shaft with an impact gun while tightening the top mount nut) Quote
shyguy164 Posted August 20, 2008 Report Posted August 20, 2008 Bushings keep the struts where they should be, no bushings or completely warn down bushings keep the struts too compact, the wear eventually seizes the struts, or at minimum prevents them from keeping the back end of the car at the height that it should be. Unfortunately I know this from experience. Fortunately the struts had warranty on them at the time so parts were free. I basically ate a new set of struts in 6 months. Springs are for ride height. Struts/shocks are for the bumpies. Quote
Breakdown Posted August 20, 2008 Report Posted August 20, 2008 Bushings keep the struts where they should be, no bushings or completely warn down bushings keep the struts too compact, the wear eventually seizes the struts, or at minimum prevents them from keeping the back end of the car at the height that it should be. Unfortunately I know this from experience. Fortunately the struts had warranty on them at the time so parts were free. I basically ate a new set of struts in 6 months. Springs are for ride height. Struts/shocks are for the bumpies. Bad struts will result in ass sag. Broken struts will result in funny car bouncing with the mono-leaf. . . . . . Mono = One and Leaf = Leaf, and that concludes your 2 week course on suspension for W-bodies. Quote
Lonewolf Posted August 20, 2008 Author Report Posted August 20, 2008 Thank's for helping so much much !!! Can anybody put a link to the exactly thing i need ??? At Napa are so many different pieces, so i don't know what is the right for my Cutty. At this time ionly change the rear shocks. I will change all wich is good for my car ... Greets Ralf Quote
