Need Pics of a Rear MANUAL dohc Mount
Here:
It's part of the intermediate shaft mount, I've already pulled the bolts that connect it to the intermediate shaft, got lazy and haven't done much since. These should be enough angles to get an idea, if you need any other pics let me know that's how it's sitting at the moment out in my garage.
and the subframe mount, they should all have this IIRC:
This is the trans mount didn't know if you needed it, but here it is anyways, you can see the mount on the trans, and it drops into the holes right by the front of the A-arm.
wowwwww.....i never knew that extra bracketry on the right rear corner of the subframe was actually meant for something other than just supporting the "ps cooler". and yes all 1st gen subframes should have that. at least ive never ever seen one without.
91+ subframes are different for the 3.4.
3.4 was first offered in 91, mine is a 91, are you saying that they changed them in 91 to work with the 3.4? Does that mean 91+ all are the same?
3.4 was first offered in 91' date=' mine is a 91, are you saying that they changed them in 91 to work with the 3.4? Does that mean 91+ all are the same?
[/quote']
Yes, until you get into second gens then they change quite a bit
