I have a nice spoiler-less trunklid. I can't line up body pieces worth a damn. Any tips?!
only snug 2 of the 4 trunk lid bolts (opposite from each other), and then use a rubber mallet to tweak it into position. Fit, adjust, fit, adjust....
at least I've had luck doing it that way anyways.
There is play in the holes, Im sure you could get lucky and bolt it on and go. But if you want perfection, some adjusting will be necessary.
