I have a leaky power steering return line that has the built in cooler that runs along the subframe. My car is a 95 cuttlass supreme with the LQ1. My question is can I just replace that return line with a hose and clamp or should I go buy the hard line for 50 bucks:question:
My euro's return line was leaking through the crimps in the rubber section before the cooler part, and i just cut out the rubber section and replaced it with some power steering hose for a couple bucks, plus some hose clamps. that was about 6 months ago, and its holding just fine.
I have done the above... but I flared the ends of the line so the hose would not slide off.
Hey... Jeff 1990Lumina did this too... but had line burst issues. was that ever solved?
Thats what I wanted to hear. I was a lil worried the pump may get too hot but its alright. I just staved $45. Thanks a bunch!!
  • 3 weeks later...
I've done both.
Replacing the entire return line is a PITA. It would be much easier to pull the engine than to try and snake the new line into place.
Replacing the leaking portion with PS hose is easier, IF you can find quality PS hose that doesn't get rock hard after a year or so.
I'm thinking of getting a couple of Earl's hard line adapters and making a -6 return hose out of Earl's PS hose and call it good once and for all.
Put it this way, book time for each Power steering line on an LQ1 is 3 hours or so for each. :rolleyes:
  • 2 weeks later...
+1 and I would call 3 hours on the conservative side.
Yes, I flared the ends and used AC Delco COLD CLIMATE P/S fluid, it's green shit but about the consistancy of water at -50 degrees lol. I also used fuel hose clamps instead of normal gear ones because the gear ones were cutting the hose.
