AxlCrucifix Posted August 11, 2008 Report Share Posted August 11, 2008 Hey guys, I'm having some problems with my sunroof in my 89 Grand Prix SE. It will vent open in the back no problem, but even with a good lubrication, has difficulty opening up and closing. (When actually opening the sunroof, not just venting it) I'm wondering what kind of drive mechanism it has, as my Haynes manual mentions nothing of it, and perhaps some suggestions as to how to make it work properly again Thanks! Quote Link to comment Share on other sites More sharing options...
jeremy Posted August 12, 2008 Report Share Posted August 12, 2008 sounds like the motor needs replacing Quote Link to comment Share on other sites More sharing options...
AxlCrucifix Posted August 12, 2008 Author Report Share Posted August 12, 2008 WHere is the motor for it? Quote Link to comment Share on other sites More sharing options...
krenzy Posted August 12, 2008 Report Share Posted August 12, 2008 Remove the headliner, you will see it. Quote Link to comment Share on other sites More sharing options...
5speedz34 Posted August 13, 2008 Report Share Posted August 13, 2008 What kind of difficulty does it have? Quote Link to comment Share on other sites More sharing options...
krenzy Posted August 13, 2008 Report Share Posted August 13, 2008 Removing the headliner or the motor? I've never taken the motor out, but it's right there when you remove the headliner, so it shouldn't take more than a couple minutes. The headliner is a sinch to remove. Quote Link to comment Share on other sites More sharing options...
AxlCrucifix Posted August 24, 2008 Author Report Share Posted August 24, 2008 If you were askin how much difficulty the sunroof has, it gets so difficult that it wont move much lol. I have never removed my headlinder before, could you please give me some idea as to how to go about it? lol thanks Quote Link to comment Share on other sites More sharing options...
Q-Ball Posted August 24, 2008 Report Share Posted August 24, 2008 You need to pull off your pillars plastic first. Than you just pull the clips off that hold the headliner on. It's easy, just try not to break the clips. Go test it in a junkyard if your really worried. Quote Link to comment Share on other sites More sharing options...
55trucker Posted August 25, 2008 Report Share Posted August 25, 2008 The motors in these don't fail often as it is protected by a capacitor that opens the circuit at the end of the sunroof full open and full closed stroke or when the motor *sees* a heavy load on it, as well as a relay in the assembly. What more than likely has happened is the drive cables are seizing and do not want to spin in their housings. (these move the track assembly on each side back & forth) To get them out to lube is a bit of a chore as they are positioned on the top side of the main assembly and that requires pulling down the complete sunroof assembly away from the roof. Removing the roof panel itself is a bit of a core as well seeing as the panel is the entire size of the cabin and to get it out you have to work it out thru the doors, and thats easier when there are no seats in the car. (been there, done that). Quote Link to comment Share on other sites More sharing options...
