kadoi Posted August 8, 2003 Report Posted August 8, 2003 okay my car isnt making anyboost at all....and my wastegate thingingy sitting on top of my turbo...its rod isnt connected to the hinge on the turbo itself....what could that do....plus i have a red wire coming out of my fuel pump relay with a grey connector on it but its not connected to anything and their is no wires around that it would connect to....please help...thanks :oops: I know im new to this Quote
TGPilot Posted August 8, 2003 Report Posted August 8, 2003 okay my car isnt making anyboost at all....and my wastegate thingingy sitting on top of my turbo...its rod isnt connected to the hinge on the turbo itself....what could that do....plus i have a red wire coming out of my fuel pump relay with a grey connector on it but its not connected to anything and their is no wires around that it would connect to....please help...thanks :oops: I know im new to this If the rod is not connected to the wastegate actuator diaphram or to the lever on the turbo itself it will make 0 boost as this what holds the wastegate closed to make boost... 8) Quote
kadoi Posted August 8, 2003 Author Report Posted August 8, 2003 thanks thats what i thought so i connected it back...but im missing the clip and it just pops right back off...i guess ill make a crap clip for now out of some wire...thanks Quote
kadoi Posted August 8, 2003 Author Report Posted August 8, 2003 now about the red wire coming off of the fuel pump relay...what could that be for...it has a grey connecter on the end and its only about eight inches long Quote
92turboLE Posted August 8, 2003 Report Posted August 8, 2003 that red wire is actually a fuel pump override... it is designed fo activate your feul pump when it is grounded, for diagnostic purposes.... the reason it is under your hood like that is cuz the pump itself is actually ontop/inside the tank, so it isnt practical to diagnose it like that, so if you have the manual override, you can tell if it is thepump or something else... thats what GM tells me anyway, kind clever, but they need to label shit - Justin Quote
GnatGoSplat Posted August 8, 2003 Report Posted August 8, 2003 That's the fuel pump prime. Connect it to +12V and the fuel pump will run. It's just to let you pre-pressurize the fuel system or for diagnostic purposes. Quote
92turboLE Posted August 8, 2003 Report Posted August 8, 2003 that too... lolz, well i was on the right path - thats what GM told me, ijust had the ground/12+ thing backwards.... - Justin Quote
kadoi Posted August 8, 2003 Author Report Posted August 8, 2003 thank because i had no clue lol Quote
