sonick Posted August 4, 2008 Report Posted August 4, 2008 okay, so I found out today the passenger side parking brake is seized. It is permanently engaged, and doesn't release. Because of this, my brake cable is full of slack and sags when released. Also, the parking brakes now barely work because only one wheel is working. The brake operates normally, so it's not a seized caliper. How do I go about trying to un-stick it? There's one big bolt holding it on; is it as simple as just loosening it, pull off the lever, clean/lube it up? Quote
Crazy K Posted August 4, 2008 Report Posted August 4, 2008 smack it with a hammer. knock the lever into the release position. but don't put your arm on the hot muffler like I did and burn it. I still have a mark from 4 years ago. Quote
AxlCrucifix Posted August 5, 2008 Report Posted August 5, 2008 i just loosened mine up for the time being first time i took it out on the road after being parked for a long time, it was stuck, and made an awlful smell after some highway driving Quote
