9lumina6 Posted August 3, 2008 Report Posted August 3, 2008 When I put on my 4 ways in my Z-34.....both the rears flash, and the driver front amber flashes....but the pass front amber doesnt. When i use my right directional.....the pass front amber blinks. Anyone know whats goen on here???????? Quote
9lumina6 Posted August 3, 2008 Author Report Posted August 3, 2008 trun signal switch or flasher? Turn signals work perfictly fine. It's just the front pass light doesnt flash when i put the 4 ways on.........my best guess would be a bad wire somewhere that goes to the hazard switch....idk?? I'm not good at all w/ electrical work/diagnosis. Quote
9lumina6 Posted August 3, 2008 Author Report Posted August 3, 2008 ok........i just went out and played w/ it........got it all worken right now....all i did was wiggle the hazard switch around a little bit and everything works OK. Now i can go get it inspected lol Quote
Crazy K Posted August 4, 2008 Report Posted August 4, 2008 sounds like you should still get a new switch, or at least open, inspect and re-lub the current switch. if you fail inspection due to brake lights... you definitely need to do something. Quote
Brian P Posted August 4, 2008 Report Posted August 4, 2008 Yeah mine does something to that effect too. Only one side will flash with the hazards. If I wiggle around the hazard button, they'll all come on and stay on. Quote
9lumina6 Posted August 4, 2008 Author Report Posted August 4, 2008 i havnt had a problem w/ it ever since i wiggled it that 1 time..... they come on every time i push the switch now. Quote
