Vortech Supercharger on a 3.1 MPFI?
My buddy just blew the motor to hell in his rustang, leaving him with no car so he's parting it out real cheap to make some cash for another car.... Meaning I can score a Vortech V-2 SQ SC-Trim supercharger for $400 CAN. I have the tools and skills to fab up all the bracketry and pully drive but this damn thing will put out 20psi, and Iam a newblet to turbo/supercharging..... So I'll need larger injectors, a custom chip(who the hell can make one and what will I need to know?), prolly a colder plug, yards of silicon hose, and what else? If this doesn't sound very feasable gimme smack upside the head cuz all I can see are dyno charts now 8) .
~BTW this will be going on my non daily driven 90' GP w/completely stock internals and no modifications, scary huh?
Supercharger specs:
VORTECH V-2 SQ SC-TRIM SUPERCHARGER
Helical cut gear profile with SQ technology
Near silent operation
Fits engines up to 680 horsepower
Maximum airflow: 1,000 CFM *
Maximum boost pressure: 20 PSI *
Maximum impeller speed: 53,000 RPM
Adiabatic efficiency: 75% **
Available with straight or curved discharge
Click here for SC-Trim models
yeah...youre gonna need some better pistons (lower compression), rings, mean heads, injectors, fuel pump, hmm...what else, maybe a boost regulator and some other random whatnots.
Well, regardless I'm goin through with this - picked up the supercharger today! All I really want is to add some moderate boost so I'll need to CNC or buy a larger pulley - I'm aiming for 12 psi max for now 8) . Other than that I'll grab some injectors outta a car in the scrapyard, like a TGP or L67 car and I'm still sourcing a chip(gonna shoot an email to FFP). No head intake/work will be done cuz it's a friggin 3.1 and I'm not pissing my money away - not to say you can't make large power but I want a much more substantial bottom end/block if it's gonna be huffin 20psi :roll: . I'll keep you guys updated on the progress when I get some spare time, until then behave :D .
heheh, for starters you might wanna try something like 8lbs boost.... I'm not sure on the strength of the stock 3.1 internals, maybe someone else can give more info?
The Jeff M Topgun 160 chips boots the boost to like 11.5psi, and thats on stock internals
Robby
Yeah, but those "stock internals" on a TGP are forged. The NA 3.1 are made of bubble gum and tin foil. :lol: I 100% doubt that thing is boosting 20 psi. Usually they are set up for around 6. So you may want to get a boost gauge and check before you make a pulley. Also, Vortech makes pulleys for it. Unless you want to for the hell of it. (BTW IF IT DOES get over 12 psi go ahead and put on a bigger pulley.) Don't see how high it will go.
Well, I was under the impression the TGP internals were the same as the n/a just something with the cranks, like the best ones were used for the TGPs or something like that
Robby
