hmdznrcld Posted July 27, 2008 Report Posted July 27, 2008 Can you guys tell me what temps your engines are running? My car seems to want to run between 210-225, my manual says the coolant relay fans don't kick in until the block coolant temp reaches 230 deg. I have been on two -three 6 mile runs with my car and she seems to be running around 220! Maybe I am being over concerned because I am so new to this engine. I just want to know where others seem to be running. I am certain I have a 195 deg therm running in mine now. Thanks Quote
ManicMechanic Posted July 27, 2008 Report Posted July 27, 2008 Mine seems to go to 190 and stay there if the A/C is on and only rise up if I sit at one of Austin's 20-minutes-to-turn-green traffic lights. Quote
birdman Posted July 27, 2008 Report Posted July 27, 2008 well when i had the 195 stat in it seemed to be really close to that, might push to 210ish with ac on. Quote
Andrew Posted July 27, 2008 Report Posted July 27, 2008 i would run a 180 t-stat if you are worried. and remember, coolant needs flushed every two years! Quote
mrl390 Posted July 28, 2008 Report Posted July 28, 2008 On the hottest day with the A/C on sitting in traffic the needle never gets to half way on my temp gauge. Quote
hmdznrcld Posted July 28, 2008 Author Report Posted July 28, 2008 Thanks guys! I went on another run today and sure enough 210 is about where I am. I have to keep in mind that I have two small radiators in the rear of the car so I know I don't get the air like you guys with a stock setup. I am going to continue to drive it and see how it responds so far it seems like it ok, today while testing it went to 220, but then with in a few minutes, more like 45 seconds it was heading back towards 215, then to 210 at idle. Quote
