I have looked at the posts but I need some help with this.
I have a 94 cutlass convertible with climate control. On a recent trip I noticed the car would not blow heat. the a.c. blows ice cold but the heater door does not open to get heat from the heater core.
I pulled the motor On the door pulled it apart and checked the motor the motor works but I don't know if the board on the motor is ok.
I have come across posts about soldering pins on the controler but there is no pics. Thats fine but i don't know what pins to solder.
I am looking for pics or links to wireing diagrams diagnostics any thing to help me solve this problem. I just changed the t stat and I know heat will come out if you open the door manualy. So the problem is in the motor or controler.
hmm.
most likely you have a clogged heater core. locate and feel the return line from the heater core. it should be nice and hot.
