I searched and searched and cant find a true complete swap. I know all the parts going to bolt up, I just need some pics, and wiring. Also hwo to put the pedals in.I cant wait to have my car 5 speeded. Its going to be sickness.
i dont think anyone has done a complete write up because there is SO much involved. but im sure a few members here who have done this will chime in.
That would be sweet. I just need to know the major things. I am really looking forward to this, I think it will bring the turbo out in my car.
M
How did you get the pedals out. I know how to get as far as taking the cluster out, top dash, etc. But how did you get the main part out to expose the pedals? Also being a 96 OBD II wiring harness what do I need to do to the wiring?
the entire dash needs to come out.....anything you see, remove it. all the hvac stuff behind it can stay. remove the entire pedal assembly with the bracket, not just the pedals. This is what you will be removing, as a whole, with the firewall plate on. plate can be detached after removing to swap on the 5spd plate if necessary...
  • 4 weeks later...
here is a question. GM- the dealership, owes me an oil pan gasket. I had them replace it and it still leaks. So What I would like to do is have them swap the tranny over when they do the pan gasket. Is there anything that needs to be done in the engine bay other than the tranny, the mounts,ect. Can I swap the pedals with out removing the engine?
For the pedals youll have to remove the master cyl but you can leave the engine in. Pedals will probably the hardest since the entire dash has to go. Also what will be hard is modifying your pcm to run a manual trans. I have yet to find a obd2 5speed swapper that has a decently running engine..
swaping the trans is not as easy as remove and replace. not by a long shot.
you have to literally convert the car.
I will make manual swap in my CSC soon, I will try to make the best how to as possible ...
