Regal_GS_1989 Posted July 18, 2008 Report Posted July 18, 2008 Anyone know if a set of 15 inch rims off a Chevy Venture would bolt up on my 2000 Regal? I'm looking for winter tires and Rims, and I come across stuff all the time from GM vans and such for pretty cheap. If these would fit, then I may just pick up a set. Quote
Brian P Posted July 18, 2008 Report Posted July 18, 2008 bolt pattern is the same, offset is almost the same. Just as long as they clear the brakes, go for it. Quote
5speedz34 Posted July 18, 2008 Report Posted July 18, 2008 Won't this mess with your odometer though? Quote
Regal_GS_1989 Posted July 18, 2008 Author Report Posted July 18, 2008 I just checked the tire calculator, and depending on which size of tires I get, the most it would be off is like 1.2% Not enough for me to worry about. Quote
jeremy Posted July 18, 2008 Report Posted July 18, 2008 I can't imagine they would fit over the brakes Quote
Regal_GS_1989 Posted July 18, 2008 Author Report Posted July 18, 2008 I can't imagine they would fit over the brakes Why not? The regal's came with 15 inch rims as the base rims, so there shouldn't be a problem. I was worried more so about the offset not being correct. Quote
jeremy Posted July 19, 2008 Report Posted July 19, 2008 I didn't know any 2G came with 15s....so I was assuming you needed at least 16s to clear them....my bad Quote
