My AC went out again..So I recharged it today but it only seems to get cooler at idle but driving warm air comes out?
mine works best when I am cruising down the highway.
did you overcharge the refrigerant?
Possibly the first time I charged it. Seems my TGP is destined to be a fall/winter weather car. So hard to get to the AC charge point sitting right next to the burning hot turbo manifold...who's bright idea was that?
You can't just keep refilling the A/C and expect it to work every time.. if you need to keep refilling it then you obviously have a problem. The system won't work properly for long once it starts leaking. You'll need to replace seals, the accumulator, and orifice tube at the least, then vacumm it and refill it (it's a little more in depth than it sounds).
