95 Z-34 not starting rite away.
shifter issues? column or floor?
Floor shifter....it's a Z-34
possibly, and yeah, the security light check *should* work like Ken described, but there are times if it makes a brief connection to the key pellet, the light won't show up.
Gear switch is a possibility too. Try fudging around with the shifter (throw it in neutral and see if it starts for you)
Dead spot in the starter, well, sometimes if you whack the starter while it's being a problem, it will clear itself up. Other than that you could test for if the solenoid is functioning all the time, etc...
