jake63 Posted July 14, 2008 Report Posted July 14, 2008 My 94 cutty 3.4 is being a huge bitch. It was idling strangely (revving high or fluctuating down low then stalling). So far I have replaced the MAF sensor, the IAC valve, all the rubber fittings on vacuum lines, and the lower intake gasket. After the gasket change I did an idle re-learn and it idled fine, took it for a ride last night and after about five minutes it went back to fluctuating idle down low and then stalling. This car is officially driving me nucking futs. I would appreciate any input that would save this car from the wrath of my .357 Thanks. Quote
CSI_MuNkY Posted July 14, 2008 Report Posted July 14, 2008 You are going to laugh at this... My car does EXACTLY what you described from time to time... All I do is clean and tighten the Aux post and its connections and the car is good as new. Jamie Quote
jake63 Posted July 16, 2008 Author Report Posted July 16, 2008 Thanks, I'll give it a shot but that stuff is pretty clean. Quote
91LuminaEuro Posted July 17, 2008 Report Posted July 17, 2008 You should check out the fuel injectors. I was having that issue and i drove myself nuts for months, replaced everything i could except for the fuel injectors because they were already brand new. Well it turns out i had two bad fuel injectors from the start. I replaced them and haven't had the problem since! Quote
jake63 Posted July 17, 2008 Author Report Posted July 17, 2008 I'll check that out too, kinda takin' a break from it for a few days. Been able to drive it like this so enjoying some top down action before the snow flies. Thanks for replying. Quote
