Bake82 Posted July 11, 2008 Report Posted July 11, 2008 Wondering what the hose in red is? I see it hooks up to the sensor with the red plug, but what is that sensor and where does the rubber hose go?. There is also a vacuum line that hooks onto the sensor in the bottom hole. Any help is appreciated. I ask because I have a stray rubber hose that seems to connect to steel line below the brake booster that goes to the fuel tank..just want to make sure I have that connected to the right place!! Thanks! Edit: Matt thanks for the pic! Quote
BXX Posted July 11, 2008 Report Posted July 11, 2008 Its the evap line... which is what goes towards your fule tank, well, actually the evap canister Quote
Bake82 Posted July 11, 2008 Author Report Posted July 11, 2008 Perfect! this is what I suspected, but was not 100% sure! thanks! Quote
BXX Posted July 12, 2008 Report Posted July 12, 2008 No problem.. The sensor it runs into is the purge control solenoid.. Really, you can do without an evap system with little or no tuning.. Quote
mfewtrail Posted July 12, 2008 Report Posted July 12, 2008 The other end of the large vacuum line connects to the metal line at the firewall(just under the master cylinder area). The small line runs over to the throttle body vacuum block. Quote
Bake82 Posted July 12, 2008 Author Report Posted July 12, 2008 Werd! ah double responses on two boards. You guys are fast...now somebody answer my much much bigger problem in the General forum...and help me out!! Quote
