z34mightymachine Posted July 9, 2008 Report Posted July 9, 2008 Hey Guys, I wanted to get some input about an EGR Valve. Has anyone changed one before. Or has anyone tried to clean it and came out with no problems after. Or would you suggest just to change it considering how expensive it is to buy? Quote
Regal_GS_1989 Posted July 9, 2008 Report Posted July 9, 2008 I kept getting an SES light on my old cutlass which was related to the EGR. i cleaned it out but i still kept getting the light. I was still getting awesome fuel mileage with it, and it ran the same so i never bothered with it again. Quote
z34mightymachine Posted July 9, 2008 Author Report Posted July 9, 2008 Reason is because I keep getting a code 32 on my Z34 92. Currently my Z34 has problems shifting into 2. It takes a while before it catches to the next gear. Tranny is not slipping. But i checked all Vaccum lines with a gauge and everything was fine. Unless I'm missing a line. Vaccum Modulator on the tranny has been changed. So my father in law said it could be that the code 32 which is the EGR or vaccum leaks on my car could be the shifting issue. I'm pretty sure eveyone with a 3.4 has had the same issue. Can someone advise what they fixed and what problem occured on your car. Quote
Regal_GS_1989 Posted July 9, 2008 Report Posted July 9, 2008 Those 2 should be unrelated. I have had that same issue with my 89 regal ever since I bought it. If you did have a vacuum leak large enough to affect your transmission, you would be noticing very harsh shifts, not long and slow shifts. I was informed that the issue was more then likely caused by a broken or weak shift accumulator spring. Quote
z34mightymachine Posted July 9, 2008 Author Report Posted July 9, 2008 I heard the same thing also that it could be an accumulator spring. Well first I'm going to have my friend at his shop scan my tranny for free to see if there is anything broken inside. If it is a big issue that the tranny will need to get rebuild I will get a used one here in Montreal. I called around and found a good one for $200 Canadian. Quote
Andrew Posted July 10, 2008 Report Posted July 10, 2008 there are TONS of threads in regards to cleaning the EGR and the pipe to it from the manifold. dont spend the big $$ on replacing it because 95% of the time that does NOT fix it. Quote
Captain Ficho Posted July 10, 2008 Report Posted July 10, 2008 My DOHC powered Cutlass kept throwing code 32 whenever I'd be exiting or decelerating on a highway. I just disassembled it, went to town on it with throttle body cleaner and reassembled it. It's been a month and a bit and I haven't gotten any codes, and I get about 15 more miles off a tank. It was seriously gummed up though. Quote
dohc v6 Posted July 10, 2008 Report Posted July 10, 2008 I do have one EGR block off plate left....... Quote
z34mightymachine Posted July 10, 2008 Author Report Posted July 10, 2008 I'm going to clean it first and see how it works. Hey dohc v6 I will keep you in mind. Thanks Quote
z34mightymachine Posted July 10, 2008 Author Report Posted July 10, 2008 Regal_GS_1989 when you changed your shift accumulator spring did the shifting problem go away? Quote
Regal_GS_1989 Posted July 11, 2008 Report Posted July 11, 2008 Regal_GS_1989 when you changed your shift accumulator spring did the shifting problem go away? I never actually changed it. I was told that was the issue, but at that time, i had my cutlass and i wasn't driving the regal all that much so i didn't bother fixing it. I've put about 30 000 km on the car and the fluid is still nice and red and the issue hasn't gotten any worse, that much i can tell you. Quote
z34mightymachine Posted July 11, 2008 Author Report Posted July 11, 2008 So I'm assuming you still have a shifting issue. My tranny fluid is nice and red also. But the stalling in the shifting is to annoying for me. So I will try to change the shift accumulator spring this week. Its not hard to do. I will let you know how it turns out. Quote
Regal_GS_1989 Posted July 11, 2008 Report Posted July 11, 2008 Yup. I adjusted my driving to it thought. Definately may do this cause I will be driving it this winter and I may tackle it before the snow flies. Quote
z34mightymachine Posted July 30, 2008 Author Report Posted July 30, 2008 Well tomorrow night I'm getting my transmission scanned to see If I have a internal issue inthe tranny. Hopefully its nothing not to big. We will see. At least I get to scan it for free Quote
