Does anyone happen to know the length and diameter of the bolts used on the front subframe. Spefifically the rear mounting part, if the front and rear mounts are not the same. I don't care about thread pitch since I will be buying the nut and welding it in...mine is fuxZ0rD.
Front/Rear bolts are the same. All 4 are. But I do not know the size sorry.
Umm...
Why weld it? A new nut/plate assembly is like 7 bucks at the dealership. Just picked mine up today.
because a new nut is like 30 cents which frees me from the $5 bolt that the setup uses (substituted with like an 80 cent bolt). Besides, I might go to custom subframe bushing and this would further ease the process.
I will likely have to cut the old one out, which means cutting the car up to get the old one out anyway.
I just like to do things my way.
I will look into this secret nut/plate though
