Bake82 Posted July 8, 2008 Report Posted July 8, 2008 Ok...the 88 Cutlass Supreme parts car I picked up had dual fans. Now when I was taking out the wiring harness today, I noticed a connecter and plug I've never seen on a w-body before. It was a plug near the coolant temp sensor on the LIM. I'm wondering if this plug is a sensor for the secondary cooling fan to tell it when to turn on? I can get a picture tomorrow if it will help, but I'm totally confused as to what it is, and this is the only thing I can think of! Thanks for any help! Kyle Quote
Brian P Posted July 8, 2008 Report Posted July 8, 2008 Early 1988's had a separate fuel cut-off switch, which later on became part of the oil pressure sensor. More than likely this is what you see. It screws into the block, on top near the intake manifolds. Quote
IRONDOG442 Posted July 8, 2008 Report Posted July 8, 2008 The secondary fan only comes on when you are running your ac compressor !! Quote
Regal_GS_1989 Posted July 8, 2008 Report Posted July 8, 2008 Or once your engine hits a hot enough temperature. I think its somewhere around 227 F where it will kick in. Quote
slick Posted July 8, 2008 Report Posted July 8, 2008 Or once your engine hits a hot enough temperature. I think its somewhere around 227 F where it will kick in. Yep, it's pretty high up there. Quote
Bake82 Posted July 8, 2008 Author Report Posted July 8, 2008 Early 1988's had a separate fuel cut-off switch, which later on became part of the oil pressure sensor. More than likely this is what you see. It screws into the block, on top near the intake manifolds. FACK!! thats probably what it is........how hard will this be to modify to work with a 88 that had this incorporated within the Oil Pressure sensor? Quote
Brian P Posted July 8, 2008 Report Posted July 8, 2008 Early 1988's had a separate fuel cut-off switch, which later on became part of the oil pressure sensor. More than likely this is what you see. It screws into the block, on top near the intake manifolds. FACK!! thats probably what it is........how hard will this be to modify to work with a 88 that had this incorporated within the Oil Pressure sensor? I think it's as easy as sending that wire down to the '89+ style oil pressure sensor. It's just a on/off switch, nothing crazy. Not sure of the pinout at the oil sensor but mayyyyybe the wire color will match up. Quote
