jdm lumina Posted July 4, 2008 Report Posted July 4, 2008 Today while i was driving home i noticed smoke coming from the steering column. I was at about 55 mph just cruising. The smoke lasted for about 5 mins. This is the only time the car has done this since i owned it. Have any of you guys had this problem. should i be worried about it. thanks for the help Quote
cutty Posted July 4, 2008 Report Posted July 4, 2008 Replace your turn signal switch. That would be the cause! Quote
89GranSport Posted July 4, 2008 Report Posted July 4, 2008 The same thing happened to me. Before you replace the turn signal switch... When it starts smoking, try quickly turning the steering wheel back and forth, while you are in park. I did this on my Regal when it was smoking, and the smoking stopped. If the smoking continues after you try that, just replace the turn signal switch. Quote
alphagtp Posted July 4, 2008 Report Posted July 4, 2008 I got lots of smoke coming thru the vents while doing a burnout Quote
jdm lumina Posted July 4, 2008 Author Report Posted July 4, 2008 I got lots of smoke coming thru the vents while doing a burnout LOL..i wish i could do a burnout Quote
wildbill Posted July 4, 2008 Report Posted July 4, 2008 Today while i was driving home i noticed smoke coming from the steering column. That used to happen to my old Lumi. I never got around to replacing it. Quote
meltboy1 Posted July 4, 2008 Report Posted July 4, 2008 ya, it's not that hard to change it, just gotta pull the steering wheen and there's only a couple screws that h old it in place. Just mark the steering wheel position or it will look like you are always turning like in my 89... I gota fix that one day... Quote
Euro Posted July 5, 2008 Report Posted July 5, 2008 yep, my old Lumina used to do it before my dad got fed up with it and paid to get it replaced Mine would smoke for a minute or so every so often...than one day it smoked non-stop for about 30 minutes...then it never did it again Quote
intern8tion9l Posted July 8, 2008 Report Posted July 8, 2008 mine lets out a puff every now and then. freaked me out at first, but now i know what it is so i just let it slide Quote
unclehotte Posted July 8, 2008 Report Posted July 8, 2008 My cutlass does it every other month. This time the left turnsignal stopped working. So I assumed I had to replace it. But the next day it was back to normal. So I can milk it longer till I have to replace it. And this started 5 years ago!! Quote
digitaloutsider Posted July 9, 2008 Report Posted July 9, 2008 Your car is about to blow up. Quit driving it, this is the first sign of the flux capacitor failing. Once it starts smoking, you're going to see some serious shit. Quote
5speedz34 Posted July 9, 2008 Report Posted July 9, 2008 Your car is about to blow up. Quit driving it, this is the first sign of the flux capacitor failing. Once it starts smoking, you're going to see some serious shit. WERD. Or your car is leaking blinker fluid into the intake manifold. Quote
Night Fury Posted July 9, 2008 Report Posted July 9, 2008 Your car is about to blow up. Quit driving it, this is the first sign of the flux capacitor failing. Once it starts smoking, you're going to see some serious shit. WERD. Or your car is leaking blinker fluid into the intake manifold. OMFMLSFGL67BBQZORZ!! Quote
Euro Posted July 9, 2008 Report Posted July 9, 2008 Your car is about to blow up. Quit driving it, this is the first sign of the flux capacitor failing. Once it starts smoking, you're going to see some serious shit. this man tells the truth. I said before my Lumina did it...why do you think I got rid of it? So it wouldn't blow up Quote
pitzel Posted July 14, 2008 Report Posted July 14, 2008 Any cheap places to find this turn signal switch? Everyone locally wants ~$100 for one. And I've taken it apart and the contacts are pretty darn worn.. Quote
Addicted to eaton Posted July 14, 2008 Report Posted July 14, 2008 I got mine for 67 bucks from oreillys Quote
