LuminaPower92 Posted June 30, 2008 Report Posted June 30, 2008 Looking at getting a motor for my 94 Cutty Convertible, does anybody have part numbers for the older 3.4 and newer 3.4? Does it matter and will a newer 3.4 Gm Long block work in a older equipped car such as my cutty. Thanks in advance. Quote
Hal H Posted July 3, 2008 Report Posted July 3, 2008 The '96-'97 engine has different heads. To start with, and you'd transfer over your intake, plenum??, and exhaust manifolds from your old (1st design) engine on a long block and that won't work on the late LQ1 engine. If you get the parts for the '96+ engine, you could probably make the change over, but I don't know if the front timing cover had different mounting provisions (alt, power steering, A/C) than the earlier designs. I believe the oil pans might be different too, but that may likely be included on the long block. Quote
White93z34 Posted July 4, 2008 Report Posted July 4, 2008 being a 94' you cannot use a 91-93 engine unless you swap the timing cover and the front cam carrier over. best replacement would be a 94-95 engine a 96-97 engine could work if you swap your intakes over, and use the 96-97 exhaust manifolds and crossover. Quote
Crazy K Posted July 4, 2008 Report Posted July 4, 2008 Should I sell one of mine? I have a 95 LQ1 with 131k in central indiana. ...since i have like 4 LOL Quote
LuminaPower92 Posted July 7, 2008 Author Report Posted July 7, 2008 being a 94' you cannot use a 91-93 engine unless you swap the timing cover and the front cam carrier over. best replacement would be a 94-95 engine a 96-97 engine could work if you swap your intakes over, and use the 96-97 exhaust manifolds and crossover. Well i ran one part number and it comes up: 10162137 Engine - Camshaft & timing - Carrier Carrier, all models, left - 3.4l 1994 - 1996 Thats on the motor, think it might be ok? Quote
