alphagtp Posted June 30, 2008 Report Posted June 30, 2008 I just took my "24 valve" emblem and it left a big ol' mess!! there is a whole bunch of glue, I have tried gogone and nothing, how can I get rid of this?? Quote
jeremy Posted June 30, 2008 Report Posted June 30, 2008 goo-gone and elbow grease always does the job on left over glue residue from emblems for me...maybe you need to add a little more elbow grease Quote
GPX Posted June 30, 2008 Report Posted June 30, 2008 Believe it or not, gasoline works really well. Be sure to wax it afterward. Quote
alphagtp Posted June 30, 2008 Author Report Posted June 30, 2008 Thanks, tried all of the above but nothing, the problem seems to be that the glue is to tick, they do nothing to it, I will get a picture tomorrow... Quote
pontiacmaniac94 Posted June 30, 2008 Report Posted June 30, 2008 Thanks, tried all of the above but nothing, the problem seems to be that the glue is to tick, they do nothing to it, I will get a picture tomorrow... you can use a hair dryer, that will help with some of the goo, also, claybar seems to work quite nicely too! Quote
alphagtp Posted July 1, 2008 Author Report Posted July 1, 2008 Thanks, tried all of the above but nothing, the problem seems to be that the glue is to tick, they do nothing to it, I will get a picture tomorrow... you can use a hair dryer, that will help with some of the goo, also, claybar seems to work quite nicely too! tried that as well and nothing Quote
Fleeingpepper Posted July 1, 2008 Report Posted July 1, 2008 WD-40? Probably bad for the paint though and I just haven't learned. Quote
GP1138 Posted July 1, 2008 Report Posted July 1, 2008 Fingernail polish remover. You only know this because you have plenty of it around. Quote
Addicted to eaton Posted July 1, 2008 Report Posted July 1, 2008 lol. Btw john i think your car is hot and i like that picture ALOT. Quote
LuminaPower92 Posted July 1, 2008 Report Posted July 1, 2008 When i was a detailer i used Solvent for that and sometimes you can use thinner lightly, but only if the car has not been repainted. Quote
wildbill Posted July 1, 2008 Report Posted July 1, 2008 It sounds like most of the adheisive stayed on the car and not on the emblem, right? This is what I did. Soak it in goo gone and scrap it with a plastic putty knife or something similar. And make sure if you remove any other emblems, that you first try to get most of the adheisive off before you use goo gone or any other solvent, otherwise you have a big ugly mess. And I would recommend using a better thread title.... Quote
GPX Posted July 1, 2008 Report Posted July 1, 2008 Believe it or not, gasoline works really well. Be sure to wax it afterward. Can't believe that didn't work. Did you light it? Quote
bodeen2007 Posted July 3, 2008 Report Posted July 3, 2008 take a razor blade and try to get as much off with out scratching the paint then use goo gone to remove the residue. It worked for me Quote
