Crazy K Posted June 29, 2008 Report Share Posted June 29, 2008 I am trying to figure out the differences between a: 1994 CS c100 with a 3100 vs a 1995 CS with LQ1 and where the second gear start wire is on a 1994 or 1995 GP. THANKS!!!!!!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
Crazy K Posted June 29, 2008 Author Report Share Posted June 29, 2008 Specifically I need: from a 1995 CS pinouts: C100's C1 K3 L2 L3 Quote Link to comment Share on other sites More sharing options...
GP1138 Posted June 29, 2008 Report Share Posted June 29, 2008 I want to add a second gear start switch to my car as well, I will keep an eye on this thread. Quote Link to comment Share on other sites More sharing options...
ManicMechanic Posted June 29, 2008 Report Share Posted June 29, 2008 the 2nd gear start wire is located on the computer, pin D6 on your computer, to activate it, supply a ground source (negative) to that pin, and you're starting in 2nd gear. (that wire is also located on the bulkhead connector E4) Quote Link to comment Share on other sites More sharing options...
Crazy K Posted June 29, 2008 Author Report Share Posted June 29, 2008 the 2nd gear start wire is located on the computer, pin D6 on your computer, to activate it, supply a ground source (negative) to that pin, and you're starting in 2nd gear. (that wire is also located on the bulkhead connector E4) Not is a 94! wait... there never was and never will be a pin# E4 second gear start 94 and 95 C100 bulkhead connector is J1. the wire exists on the engine side of the car only, on our cars. John, You want second gear start? next time i pass through Quote Link to comment Share on other sites More sharing options...
rockfangd Posted June 30, 2008 Report Share Posted June 30, 2008 i also would like to know how to do this. i believe it would help my takeoffs in the winter lol. Quote Link to comment Share on other sites More sharing options...
