ryan.h Posted June 26, 2008 Report Share Posted June 26, 2008 Door won't open from the inside or out. At first I thought the linkages might be shot again, but I pulled the corner of the inside door panel off, and I can manipulate the linkages and the latch lever itself. BUT, it acts like it is locked, because moving the lever does not open the latch and door. I've been fooling with unlocking/locking it, in and out door handles in different combinations..... with no luck. What should I do? Quote Link to comment Share on other sites More sharing options...
rockfangd Posted June 26, 2008 Report Share Posted June 26, 2008 i am going to guess 2 door GP, the lock is probably binding with the latch assembly. i usually just open the window, push on the door and wiggle the outside handle and the door until it pops open, once it is open hit it with some good lithium grease Quote Link to comment Share on other sites More sharing options...
