cutty Posted June 30, 2008 Report Posted June 30, 2008 I just had the same problem with my cutlass, i had to replace both rear calipers, and rotors. I also flushed out the brake fluid. It stops so much better now. With no problems at all so far. Quote
rockfangd Posted June 30, 2008 Report Posted June 30, 2008 my cutalss has always been like that. the pistons collapse normally and everything looks good until the brakes start to wear. I will post a pic of my month old brakes tomorrow lol. Ken, GP's normally didn't get the aux springs, except some LE's. I've seen a few on GPs... cars that have aux springs that i have seen are: convertibles (maybe all of them?) base model cars without a rear swaybar sporty models with a rear swaybar. many 3.4 cars... (including a 95 GTP) in fact... everycar i own has them except both my 95s! my 91 euro did not have them... so 8/11 Ws that I;ve had had aux springs... granted... those aren't GPs... So i just want to know what the Aux springs may have to do with the brakes because i have those PITA 8 shaped springs lol Quote
55trucker Posted June 30, 2008 Report Posted June 30, 2008 I'm getting the impression that the caliper piston is seizing/seized. It will apply due to the fluid pressure applied to it but it can't release fully on its own so it hangs on. As for the caliper slider pins, altho you've purchased some already there is a carbon fiber pin kit out there that will put a total end to the pins seizing, I purchased this kit some 12 years ago and have had no issues with my rear brakes since. Quote
Robby1870 Posted June 30, 2008 Author Report Posted June 30, 2008 Bought a caliper and bracket today. $125 total. I'll be getting $25 back on core charge though. Probably get it replaced on the holiday. Quote
Crazy K Posted July 1, 2008 Report Posted July 1, 2008 So i just want to know what the Aux springs may have to do with the brakes because i have those PITA 8 shaped springs lol 93- aux springs are mounter further outboard, and interfere if used with 94+ brakes. Quote
rockfangd Posted July 3, 2008 Report Posted July 3, 2008 Great thing to know. at least it wont affect me Quote
cutlassdude96 Posted July 3, 2008 Report Posted July 3, 2008 my right rear caliper has got problems now, I cant get it to come off the slider to lube it back up Quote
Robby1870 Posted July 5, 2008 Author Report Posted July 5, 2008 And the problem is/was........... Clogged brake line, the rubber part. So, I ordered a line for a 1994 and one for a 1990. I had the 1990 line on there, and I hope the 94 line is long enough. But if it's not, I'll just use the new 1990 line. I put the new caliper on and tried to bleed it and nothing came out, so I took the rubber line off and viola, fluid came out. Quote
rockfangd Posted July 6, 2008 Report Posted July 6, 2008 i wish that was my problem, when i pressure bled mine they bled fine Quote
Robby1870 Posted July 6, 2008 Author Report Posted July 6, 2008 New line installed, brakes work fine. Quote
1990lumina Posted July 7, 2008 Report Posted July 7, 2008 I'd recommend you flush the rest of your brake system if there is enoguh shit in it to cause the whole line to plug up! Quote
Robby1870 Posted July 7, 2008 Author Report Posted July 7, 2008 WTK? WTK? What is that? Yeah, somehow that old line got clogged or something. The new 94+ rear line ended up being too short so I had to use the new '90 line. No big deal. I didn't even look at the old line to exactly what was wrong with. After getting my arm covered in brake fluid several times replacing it, I was too mad to even mess with. Straight to the dumpster! Quote
Robby1870 Posted July 7, 2008 Author Report Posted July 7, 2008 I'd recommend you flush the rest of your brake system if there is enoguh shit in it to cause the whole line to plug up! Yeah, I thought about that. I feel like the problem was just in that line though since I've had on other issues with the brakes. I don't really have time for that since I'm moving next weekend. Quote
Brian P Posted July 7, 2008 Report Posted July 7, 2008 it may be too late now, but the '93 lines are all-rubber and might be a bit longer than the '94s. WTK = what the koala Quote
Robby1870 Posted July 7, 2008 Author Report Posted July 7, 2008 it may be too late now, but the '93 lines are all-rubber and might be a bit longer than the '94s. WTK = what the koala Ah. Good to know. I didn't really have time to mix and match parts. Although, I will look into the 93 lines as I'd like to redo the rear brakes with all rubber lines. Quote
BXX Posted July 7, 2008 Report Posted July 7, 2008 When brake fluid isnt flushed properly at certain intervals it has a high copper concentration and of course, its hydroscopic so it absorbs water and when its so high of a level and old it will eat away at the system and cause clogs and lines to rot out prematurely from the inside out.. Not uncommon to have old hoses clog and collapse due to the contamination Glad to hear you got it fixed Quote
