Identity Crisis Posted June 19, 2008 Report Posted June 19, 2008 96 3.4DOHC Auto When just light peddling the throttle and the car hits 1700RPM it starts to shutter and then when it goes over 2000 RPM it goes away. I have changed the plugs and wires and all of the upper intake, intake tube and throttle body gaskets, PCV, air filter, oil changes etc and nothing helps it. There is a listing in my snap on scanner for this issue but there is not explaination. Does anyone have a clear idea of what the hell is going on? Quote
RareGMFan Posted June 19, 2008 Report Posted June 19, 2008 I don't know if there is something else that the LQ1 is prone to that may be causing your issue, but I know I've had several cars shutter pretty badly at certain RPM when a coil or 2 was toast. The ones on my TGP literally had cracked casings that were arcing like crazy, to the point that they would make the motor shutter if I pressed any harder than 1/4 of the way down on the accelerator. Quote
Identity Crisis Posted June 20, 2008 Author Report Posted June 20, 2008 I replaced the coils at the same time I did the wires. Quote
89SupremeCutty Posted June 20, 2008 Report Posted June 20, 2008 when this happens are you in gear or idling in park/neutral? Quote
Night Fury Posted June 20, 2008 Report Posted June 20, 2008 Mine does the same freaking thing, except it's a 3.1 Quote
BXX Posted June 20, 2008 Report Posted June 20, 2008 bah, not again.. change your transmisssion fluid Quote
Night Fury Posted June 21, 2008 Report Posted June 21, 2008 bah, not again.. change your transmission fluid Me? Its brand new fluid and completely full. Quote
Identity Crisis Posted June 21, 2008 Author Report Posted June 21, 2008 This happens while driving only. And the trans fluid was changed 5000kms ago. Quote
BXX Posted June 22, 2008 Report Posted June 22, 2008 Shuddering with no signs of an engine misfire is 99% of the time transmission fluid or transmisson torque convertor/internal issues. Quote
Identity Crisis Posted June 22, 2008 Author Report Posted June 22, 2008 I thought this shuttering was a common issue with these cars? Quote
1990lumina Posted June 22, 2008 Report Posted June 22, 2008 Either that or maybe you have a worn out mount or two. My Lumina used to shudder with the worn out lower mount when the fluid leaked out of it Quote
89SupremeCutty Posted June 22, 2008 Report Posted June 22, 2008 Shuddering with no signs of an engine misfire is 99% of the time transmission fluid or transmisson torque convertor/internal issues. i was thinking tcc. try unplugging it from the outside of the trans and drive it and see if that does it. Quote
BXX Posted June 22, 2008 Report Posted June 22, 2008 Either that or maybe you have a worn out mount or two. My Lumina used to shudder with the worn out lower mount when the fluid leaked out of it That wont cause a shudder on its own... Trust me, I have every mount pretty much blown on my CS with no shuddering whatsoever... Now that I remember, I never had a W with good mounts Quote
Identity Crisis Posted June 22, 2008 Author Report Posted June 22, 2008 TCC? I will give that a try this week. Is it on the Drivers side? Quote
Captain Ficho Posted June 24, 2008 Report Posted June 24, 2008 Either that or maybe you have a worn out mount or two. My Lumina used to shudder with the worn out lower mount when the fluid leaked out of it That wont cause a shudder on its own... Trust me, I have every mount pretty much blown on my CS with no shuddering whatsoever... Now that I remember, I never had a W with good mounts Seconded... all my mounts were shot and I never had any shuddering. But I finally got around to changing them last week. I'd be be inclined to believe it is a trans problem as well. Quote
Brian P Posted June 25, 2008 Report Posted June 25, 2008 look at the ignition coils in the dark and check for arcing between the terminals. Spray some water mist around there too, that might help it show up. Quote
Identity Crisis Posted June 26, 2008 Author Report Posted June 26, 2008 I just changed the coils this DEC and it was doing this before and after. Quote
89SupremeCutty Posted June 26, 2008 Report Posted June 26, 2008 sound slike the tcc to me. it's located on the drivers side on the front of the trans closest to the radiator. if im wrong someone correct me. i remember on my cutty that's where it was. Quote
