meltboy1 Posted June 19, 2008 Report Posted June 19, 2008 Ok so the cars been fine, not a sputter, spit or stall since I got it nick... this is the 89 GP 5spd guys... well I go to leave the bar tonight and I go out and start the car and it stalls out... do it again and stall, and it kept doin it... I had to give it constant gas the whole way to his house then back to mine, the second I let off the pedal it would stall.... what the hell am I lookin at here, please tell me it's something stupid... Quote
Andrew Posted June 19, 2008 Report Posted June 19, 2008 so it wont idle is what you are saying. then i say IAC. Quote
ns87 Posted June 19, 2008 Report Posted June 19, 2008 check the fuel pressure with a gauge, sounds like the fuel pump to me Quote
Venom Posted June 19, 2008 Report Posted June 19, 2008 Might have a vacuum line off also, causing it to die out when idling. Quote
kaptnjack Posted June 19, 2008 Report Posted June 19, 2008 mine started this similar thing yesterday too. Start it,,,stumbles and dies, start it...pat the gas and try to get up rpm but sputters and misses and will try to die. let it idle and it will but weakly. Strange,,,let it sit 20 minutes...fire right up and run like a top. Then drive around ten minutes and cut it off...try to start it back and no go...have to raise the hood and let it cool...seems like. The car has a new stat and is cooling nicely. no intention to hijack but my issue is similar...I will share what I learn. Quote
meltboy1 Posted June 19, 2008 Author Report Posted June 19, 2008 ya, I thought vacuum line or the plug that goes to the air filter box, so I checked and every line seemed to be connected that I could see, took out the air filter to check it, and it wasn't dirty... but it wasn't clean either ya know, so I shaked it off a bit... started it up and it ran fine shortly after my post last night. I don't have a fuel pressure tester yet, I plan to pick on up, they are fairly cheap. Quote
RareGMFan Posted June 19, 2008 Report Posted June 19, 2008 Testing the fuel pressure is a good start. Way too many possibilities that need to be narrowed down. Also, when you press the accelerator to keep the car running, does it run smooth, or is it missing/sputtering at all? Quote
meltboy1 Posted June 20, 2008 Author Report Posted June 20, 2008 Gah..I hate to waste my 500th post on a response to a question, but since it is helping me out it is ok... lol I drove it around today a good while and it was fine, not a single problem since I checked everything last night. But to answer your question, no it didn't sputter or anything, it was smooth as long as I was moving or giving it gas, but the second I put the clutch down if I wasn't giving it gas it just died right out. Weird, but I think what happened was... that sensor on the air filter box is the IAC right??... well when I took it off a couple weeks ago the clip broke so it just sits in there, I am thinking maybe it shook itself loose, cuz after I looked at everything and plugged it back in, it's been fine. Quote
intern8tion9l Posted June 20, 2008 Report Posted June 20, 2008 that sensor is the IAT(intake air temperature)...the IAC is on the front side of the throttle body Quote
rockfangd Posted June 20, 2008 Report Posted June 20, 2008 x2 the iac is on the TB. you cant miss the iat sensor Quote
