meltboy1 Posted June 15, 2008 Report Posted June 15, 2008 Well I just got home and parked the TGP, and went to park the 89 GP in front of it, get in... start it up, turn on the lights, and I have no dash or DIC lights... what's the deal? edit... I should mention that also when I turn on the lights normally, the speedo is too dim to see, it's the digital speedo and everything else is analog. Quote
meltboy1 Posted June 15, 2008 Author Report Posted June 15, 2008 ok a little more... I just went to get some coffee, and the green for the directionals lights up, blue for high beams also works. I also noticed the buttons for the seats on the center console aren't lighting up either. Quote
Q-Ball Posted June 15, 2008 Report Posted June 15, 2008 Had the same problem. The DIC and AQ9 nights didnt light up. Turned out to be a ground issue I think. Take it apart and check it out. Quote
meltboy1 Posted June 15, 2008 Author Report Posted June 15, 2008 Well turned out it was the 5 AMP panel fuse... I put another in and it blew right away, and tried a second and that one held... maybe they were both just bad fuses? I did pull one spare out of the TGP which looked like it was an original extra 20 year old fuse... idk give it a few days and see if it holds. Quote
meltboy1 Posted June 15, 2008 Author Report Posted June 15, 2008 Ok, so it blew again today... where should I start diagnosing this? Quote
grandprixnyc Posted June 16, 2008 Report Posted June 16, 2008 Its either the old fuse you used, or there is a short somewhere. If a NEW fuse doesn't work, then its time to start pulling apart the dash. It happened to me once. I was driving home at 4AM and all of a sudden all my lights go out. Freaked me out... was just the fuse, though. They are old, and they tend to blow easier. Quote
meltboy1 Posted June 16, 2008 Author Report Posted June 16, 2008 idk this is the third fuse, I think I am ruling out bad fuses now... I am more concerned on a common place this may be occuring if it's happened to others. Quote
grandprixnyc Posted June 16, 2008 Report Posted June 16, 2008 grounds could be bad... theres hundreds of feet of wire to check! Have you altered anything in the car that might be the source of the problem? Quote
GOT2B GM Posted June 16, 2008 Report Posted June 16, 2008 theres a coin in your cigarette lighter socket Quote
meltboy1 Posted June 16, 2008 Author Report Posted June 16, 2008 no, there is a cell phone charger in my cigarette lighter socket... lol Well there was an aftermarket deck installed in there... kinda crappily too from looking at it, I will start there tomorrow I suppose since I plan on swapping decks between this car and the TGP anyway. The only thing electrically I modded was I added a second 12V supply socket which I wired into the accesory fuse, just tapped off the load side, and yes it is done right, and grounded it to where there was a screw going to the body under the dash somewhere. But that was 2 weeks ago, I have done nothing recently that I can think of that would have affected it. Quote
Guest Posted June 16, 2008 Report Posted June 16, 2008 theres a coin in your cigarette lighter socket wrong circuit Well there was an aftermarket deck installed in there... kinda crappily too from looking at it, I will start there tomorrow I suppose since I plan on swapping decks between this car and the TGP anyway. sounds like the problem. someone else just had this problem. The dimmer wire is getting shorted. Quote
meltboy1 Posted June 16, 2008 Author Report Posted June 16, 2008 theres a coin in your cigarette lighter socket wrong circuit Well there was an aftermarket deck installed in there... kinda crappily too from looking at it, I will start there tomorrow I suppose since I plan on swapping decks between this car and the TGP anyway. sounds like the problem. someone else just had this problem. The dimmer wire is getting shorted. ok thanx, I was just gona say today why would it matter if a coin was in there, but you covered that for me... lol I really hope it is something that simple. Quote
Venom Posted June 16, 2008 Report Posted June 16, 2008 i was going to say the same thing about the coin until I realised it was on a different circuit. I would suggest looking at the deck wiring first and start tracing all the wires. Quote
meltboy1 Posted June 16, 2008 Author Report Posted June 16, 2008 well i am in the car now and it is holding so far with a new fuse... new in box, I checked the deck wiring and it was all safe... no shorts in there.... what now if it goes again? Quote
mfewtrail Posted June 17, 2008 Report Posted June 17, 2008 If it pops again, you have a short somewhere. It probably only happens randomly because the wire/connection is not shorted all the time, but when you drive and stuff moves around it makes contact and blows the fuse. Let me know if you need an interior wiring diagram. Quote
Guest Posted June 17, 2008 Report Posted June 17, 2008 yea the dimmer circuit shouldn't be too hard to trace in the GP. You're looking at radio, climate controls, DIC, cluster, the headlight/wiper switches and the SWRC buttons, so it's not some huge circuit that's all over the car. I can't remember if the lock or window switches are illuminated or not, so maybe them too, I know the Cutlass's are. But if it happens again, either you have some continuity checking to do, or try unplugging components in the circuit individually to see if it's still happening. Most likely it's some wire though, not a component. Quote
Gearhead43 Posted June 24, 2008 Report Posted June 24, 2008 Dimmer switch could be bad... Like I've stated in the other post...... Quote
