dohc v6 Posted June 13, 2008 Report Share Posted June 13, 2008 I want to have my high beam on with my low beams, any way to do this?? M Quote Link to comment Share on other sites More sharing options...
bullet Posted June 13, 2008 Report Share Posted June 13, 2008 I want to have my high beam on with my low beams, any way to do this?? M yup, couple ways.... first you can do this - connect wire to battery atach 15-20 amp fuse, what ever it is, and hook up the low beams or high beams like foglights to a switch. your choice which you can rig-up or this - highs and lows wired together, always ona at the same time (kinda dumb) Quote Link to comment Share on other sites More sharing options...
z34Phoenix Posted June 14, 2008 Report Share Posted June 14, 2008 bullet missed the part about using a relay. use the low high beam wire as a trigger for the relay ... use battery to power the relay and then the output will be spliced into the low beams. that way you turn on your high beams it triggers the relay that will power up the low beams. Quote Link to comment Share on other sites More sharing options...
meltboy1 Posted June 14, 2008 Report Share Posted June 14, 2008 bullet missed the part about using a relay. use the low high beam wire as a trigger for the relay ... use battery to power the relay and then the output will be spliced into the low beams. that way you turn on your high beams it triggers the relay that will power up the low beams. Ya, what he said, just beat me to it. Quote Link to comment Share on other sites More sharing options...
dohc v6 Posted June 14, 2008 Author Report Share Posted June 14, 2008 Can you post a sketch of what you mean? Also do you have a part # for the relay. I want to do this tomorrow. M Quote Link to comment Share on other sites More sharing options...
BXX Posted June 14, 2008 Report Share Posted June 14, 2008 Wire them like the CS's and I think the GPs too with the MiniQuads... Flip on the brights with the switch and the lows stay on Quote Link to comment Share on other sites More sharing options...
bullet Posted June 14, 2008 Report Share Posted June 14, 2008 bullet missed the part about using a relay. use the low high beam wire as a trigger for the relay ... use battery to power the relay and then the output will be spliced into the low beams. that way you turn on your high beams it triggers the relay that will power up the low beams. damn, thanks for the reminder. yeah I can take som picks of me wiring the bulbs together...but unfortunately I don't have my new 89TGP yet so it will justy be bulbs if that helps. Quote Link to comment Share on other sites More sharing options...
5speedz34 Posted June 14, 2008 Report Share Posted June 14, 2008 Wire them like the CS's and I think the GPs too with the MiniQuads... Flip on the brights with the switch and the lows stay on Doesn't dim the low's though? Quote Link to comment Share on other sites More sharing options...
dohc v6 Posted June 14, 2008 Author Report Share Posted June 14, 2008 I just need to know what wires need to be attached to the relay and what relay I need. Can I use a fan relay?? M Quote Link to comment Share on other sites More sharing options...
dohc v6 Posted June 16, 2008 Author Report Share Posted June 16, 2008 Sketch please. M Quote Link to comment Share on other sites More sharing options...
BXX Posted June 17, 2008 Report Share Posted June 17, 2008 Wire them like the CS's and I think the GPs too with the MiniQuads... Flip on the brights with the switch and the lows stay on Doesn't dim the low's though? No, the lows stay the same brightness Quote Link to comment Share on other sites More sharing options...
xtremerevolution Posted June 17, 2008 Report Share Posted June 17, 2008 Wire them like the CS's and I think the GPs too with the MiniQuads... Flip on the brights with the switch and the lows stay on Doesn't dim the low's though? No, the lows stay the same brightness x2. The Lights will just draw more power, not split up the amount of power they have available. Quote Link to comment Share on other sites More sharing options...
bullet Posted June 17, 2008 Report Share Posted June 17, 2008 Wire them like the CS's and I think the GPs too with the MiniQuads... Flip on the brights with the switch and the lows stay on Doesn't dim the low's though? exactly No, the lows stay the same brightness x2. The Lights will just draw more power, not split up the amount of power they have available. Quote Link to comment Share on other sites More sharing options...
