crazy idle....gettin really annoyed
i ran into the same exact problem last year with my 94 cutlass the morning after a thunderstorm and i was going crazy. I knew if i tried to drive it the engine probably would have torn through the hood and kept going lol.
I changed the IAC, no fix, TPS, no fix, Then i did the CTS and an idle relearn and then it was perfect. HOPE yours can be that easy
just curious.. but have you checked the TB and the idle screw on there? or maybe the trottle cable gets stuck in the housing.
mine actually fixed itself after i pushed a tube into place... this was loose in the back of the engine (its off for the picture)... its circled as to here
huh thats been happening to me sometimes when i started my car up it would idle a 2000rpm and sometime not i did happen to notice one of the vacume lines came off so i put it back in and it hasen't done it in awhile
i turned the idle screw down as far as it will go. and the butterfly always snaps closed when i let off the throttle.....i checked
