5 speed from beretta
went to the j/y today because of an incident with a deer last night, looking for a passenger door and fender. came across a beretta with a 5 speed, what all needs to be modified to work with a 95 monte? it looks like everything was there to salvage. according to the hood it came with a 3.1 and is model year 94. according to wikipedia, thats not possible. is it obd1.5 or 1? i cant remember what all models gm fucked in 94-95 with the shit.
1994 Berettas had the 3100, not 3.1. Either the hood was replaced or it was a 2.2 or Q4 car. And an L body trans won't even come close to bolting up in a W.
I thought as long as it was a V6 L body it was a feasible scenario with a little bit of fab work...
I believe the bellhousing is different.
really??? I find that rather surprising... but hey, you never know
Bellhousing is same. It's the rest that's different.
Maybe I was thinking of the J-body transmissions.
:razz:
The the bellhousing will bolt up fine, but the W-body case is the only one that will bolt into a W without fabwork. NONE of the other cases have provisions for our mounts to bolt up, and of course the slave setup is different but that's probably an easy enough work around. Another thing is that only Ws (and a few Berettas, not sure on specifics) ever got the intermediate shaft, but I'm fairly certain that the Beretta's is shorter than ours.
  • 2 weeks later...
not to mention, the gear ratios would be different than a w-body trans.
Actually, from my research it appears that V6 W and V6 J 282s have the same ratios. I confirmed that V6 W gearing is 3.50/2.05/1.38/.94/.72/3.61, and most info I've seen on J's shows the same.
i thought the W-body V6 282 gearing was 3.77, 2.19, 1.38, 1.04, .81 with 3.61 FDR? at least that is what 60degreev6.com used to show. i was under the impression that all J/L V6 282 got 3.50, 2.05, 1.38, .94, .72 + 3.61 FDR. which i guess would make sense since the W is heavier than the J/L body.
come on Josh, we already went over this :lol:
http://www.w-body.com/forum/index.php?topic=68132.msg862999#msg862999
the ratios you posted are for Q4 W's only (3.77/2.19/1.38/1.03/.80/3.61)
edit: someone updated wikipedia, that info's right now.
ah crap i totally forgot about that! i spend too much time thinking about Mopar stuff these days :lol:
I have a 5 speed from a 91 GTZ, for a HO Q4. in case I ever get to make a Q4 5 speed car. it was cheap enough....
it has no intermediate shaft housing. it has basically a "cv axle extension" shaft that comes right out of the passenger side of the tranny, unliek the W282s that have a extension to the case.
how are Q4 W body 282s configured????? w extension shaft in a housing, or just a direct extension shaft without a housing?
Same as V6 282s.
