Floating/Jumpy Fuel Gauge & A/C Dropping Out: 1995 Cutlass Convertible - Help!
I just looked at 1995 Olds Cutlass Supreme Convertible, with 113k at a new car dealer (he took it in on trade).
Two things I did notice in the test drive:
a) With the A/C going, upon acceleration, the A/C "dropped" out to almost shutting off, and then back under normal coasting, it came back. Is this a major problem? Is it just a timing issue? It happened a few times.
B) The fuel gauge "floated" - showed a half tank, then moved down to below a quarter, then back. It seemed to happen a few times as well, under acceleration but coasting as well.
Any answers to the above questions would be greatly appreciated. Overall, the car seemed tight - but don't want to proceed without a good idea of price and whether these issues would be big bucks to repair. Thanks!
the "floating" of the fuel gauge is common. My old Lumina did it and I believe others have done it as well.
Vacume leak most likely.
For the A/C?
I'm betting that the A/C actually starts blowing out the defroster vents and floor vents upon acceleration meaning the 3 way check valve, vacuum tank or vacuum line is broken...
Yeah for the a/c But jay gave you some more ideas what might be wrong with the a/c
