trans question or 2 actualy
1 i have a 1991 gp and every time i try to make a left hand turn at any kind of speed the trans acts like it gets out oif gear and the engine will rev to like 4 grand then it will catch again. i was wonderin if any of you have had this prblem and what you did to fix it
2nd i have a 1994 gp se parts car with a trans with less than 15000 on it i wandering it will go in the 1991 with out and major problems ( wiring mounts ETC)
1) Check the transmission fluid level.
x2
I had the same problem. Only mine would hit redline, not just 4000.
x2
yup, common problem when low on fluid. remember, check when fully warmed up, not cold like motor oil.
x2
x2, and make sure it is checked on a level surface.
and tranny mounts. Mine likes to do that when I go up a hill, broken tranny mount. Similar problem, though they're probably right and you're just low on fluid.
